The first thing to do is smell it. If it smells burned, it is probably fried. If it isn't working after being plugged into 220, there won't be a fix. Armatures & field coils aren't available for these.
Need electrical schematic for Dremel Model 285 tool, looks like microchip is mechanicaly damage,...
(More)
Need electrical schematic for Dremel Model 285 tool, looks like microchip is mechanicaly damage, hence does not provide voltage to the motor. Want to replace the chip
nice greetings please i need help I have Kango rotary Hammer. type 750X which is broken piston....
(More)
nice greetings please i need help I have Kango rotary Hammer. type 750X which is broken piston. whether it is possible to order only the piston and the price would be? advance thanks to the response Lukica
dremel tool # 572.610530, variable speed (1 to 5) purchased in 1998. The tool could be made to...
(More)
dremel tool # 572.610530, variable speed (1 to 5) purchased in 1998. The tool could be made to operate by moving the speed control back and forth. Finally it died. It has not been abused, brushs were replaced, and it will still not run. I suspect that it needs a new variable speed control switch? Thank you for for your time.
I have a Dremel 300 and the shaft lock assembly isn't working to hold the shaft so I can get the...
(More)
I have a Dremel 300 and the shaft lock assembly isn't working to hold the shaft so I can get the collet nut loose. When I try to get the collet nut loose while holding the button of the shaft lock the shaft lock just spins along with the collet nut so I can't get the nut loose.
