Question about Bloomfield 8571 Coffee Maker
Water does not displace...
We inherited this coffee maker from a college ministry in town. I suspect the students didn't know how to work it.
However, I plug it in, wait for the brew light (feels like there's water already in the tank). It turns green after about 30 minutes.
I pour in new water...
It heats the water in the top tray, but water is never displaced to the pot.
Now I have HOT water sitting in the top tray and nothing has come out into the pot.
All lights are working...
  • journeyguy Jan 06, 2008
    It's the Bloomfield 8571, but I fixed it yesterday. Thanks for the response though.
    I removed the pan that the water is poured into and disconnected all rubber tubes. Upon examination, the tube that connect to the top of the dispenser (where the hot water is supposed to come out) was clogged with nasty black, gooey gunk.
    I cleaned it out and voila!!
    I ran about 10 pots of hot water through the system to get it running clear water again.
  • 146 Answers
If you give us the make and model we'll see what we can find for you.
Posted on Jan 06, 2008
Why does coffee come out while pouring in water its a bunn 10 cup coffee maker
The Bunn has a little stopper that closes the water drain port in the reservoir while the lid is open. You can see a little white plastic pin protruding up out of the grate with the lid open. When you close the lid, it pushes on that pin which causes the stopper to lift off the drain port, allowing the water in the reservoir to enter the heating tank.
If water is entering the coffee basket BEFORE the lid is closed, then something is wrong with that little stopper. It may have a chunk of debris on it preventing it from sealing, or it may be deteriorated, torn, disconnected, etc.
Only way to know is to remove the the screws in the grate and pull the top off exposing the reservoir, and the stopper assembly. The little plastic flapper disc should be seated in the reservoir drain port. It should be relatively flat (not wrinkled) and covering the drain port completely. Test it by pouring some water into the reservoir. If it drains out without you activating the stopper, then a repair is needed.
Move the lever up and down and check its operation. The arm must move freely and close when released. There should be no dirt or debris on the sealing surface of the flapper nor on the sealing surface of the drain port. Gently clean with vinegar as necessary. If the seal is damaged, then a replacement is required.
Nov 29, 2014 | Bunn 10 Cup Home Coffee Brewer
Cuisinart coffee pot
his EXACT situation happened to me 2 days ago because it gets clogged. Flush and dump clear HOT water threw the tank several times. When I did this, clumps of coffee came out and the coffee maker worked great again. In was my bad because the manufacturers say to run a clear vinegar flush threw them once every 6 months, followed by 2-3 clear water flushes to remove these "clots" that plug it up. Hope this info is not too late and you didn\'t throw your machine out. :)
May 07, 2013 | Coffee Makers & Espresso Machines
I just got the exact IcedTea maker that you have (model TM4) from Mr. Coffee. I think that we were both trying to make it work the same way, which is wrong. The plastic pitcher goes on the bottom, while the part that plugs in with the button&indicator light goes on the top. Put water in the pitcher to the indicated water line and then pour it into the part with the metal basket. I didn't have any directional sheet either so I didn't know that the water goes in there. I thought the water would be gently warmed while in the plastic pitcher. After pouring water into the heating part, fill the pitcher with ice to indicated level (about 2 ice cube trays). Place the heating part with the button&indicator light on top of the plastic pitcher and cover it with the white lid. Push the button and it will heat the water and dispense the brewed tea into the pitcher thru a valve. The indicator light will go off when the brewing process is done. The entire manual can be downloaded from going to: I hope this helps you if you still have the item. I bought mine to give my daughter while in college. I really like that it is so space saving compared to many that I am finding in stores today. Good luck and happy brewing!!! Susan
Mar 05, 2011 | Vacuums
My keurig coffee maker and my sister had a strange thing happen to us concerning our coffee maker. I few weeks ago her coffee machine was on the off posotion and it turned on by its self and started to...
check to make sure that they don't have a timer and if they do that it is not set to go off when you don't want it to. If this doesn't solve the problem I would definitely not leave it plugged in when you are not using it. Also I think you should contact the company and let them know what is going on and see if they can replace it.
Aug 05, 2010 | Keurig B100 Coffee Maker
How do I make coffee with a Grindmaster Pourover Coffee maker?
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Bunn auto coffee maker two warmer, only makes about 3-4 cups
The machine will allow you to brew from 4-10 cups. It works on a displacement systems so if you pour in 4 cups of water, then 4 cups of coffee should come out. If it isn't, then get the model and date code from the bottom of the unit and call customer service. If you machine is 3 years old and less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Dec 02, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Water through frothing wand
It might sound silly but you haven't got the steam valve on the right hand side open have you?
Nov 27, 2008 | Gaggia Evolution Espresso Machine
Black & Decker DCM1350 Coffee maker
coffee pot will not turn there an internal fuse worked find the last time it was used
Oct 11, 2008 | Coffee Makers & Espresso Machines
Inherited coffee maker I have a Faberware ?138? Automatic Peculating Coffee Maker I inherited from my Grandparents. It's in great shape but I have no idea how old it is. It's a great little unit, but...
There realy not much of a manual for this type of coffee maker. put water in to water line, put coffee in the metal basket, put the lid on the metal basket, put lid on the coffee maker, set it on the stove until it starts peculating let do it for 10-min then stop.
Sep 06, 2006 | Faberware FCP412 Coffee Maker
Bloomfield 8571 Coffee Maker Logo
119 people viewed this question
Top Bloomfield Coffee Makers & Espresso Machines Experts
Kelley Hopper
Level 1 Expert
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
