Check to see if the compressor is running. There is an overload on the relay that sometimes goes out. If it is the relay you can hear the compressor kick on and off every couple of minutes. To check the compressor shoot for continuity between the stand alone terminal and the other two. Each should have about 4-12 ohms. Check the evaporator fan in the back of the freezer. Make sure the coils in the back of the freezer do not have too much ice build up. If all of these check good you have a freon leak.
Ice is forming at the back of the fridge, even if i keep the temperature at 2. Freezer is working...
(More)
Ice is forming at the back of the fridge, even if i keep the temperature at 2. Freezer is working fine
I have a KitchenAid Superba and the water dispenser works intermittently. Now it has been two weeks...
(More)
I have a KitchenAid Superba and the water dispenser works intermittently. Now it has been two weeks and still no water. In the past, the dispenser would randomly start working again. During these issues, the ice making has worked flawlessly! I have checked the filter but think it is fine. Any thoughts out there??? Thanks in advance! bg
