Canon ZR200 Mini DV Digital Camcorder
Vista and firewire 1394?
shared by 3 users
posted by bensn2o on Jan 05, 2008
I have been reading that Vista does not support 1394 firewire? I am trying
to hook up my video camera to capture and Vista does not see the camera
attached to the 1394 port. How can I get Vista to see it?
I purchased a 1394 4 pin firewire (camera)/ USB to attempt to download video from my camera's Mini DV tapes. my computer is new and only has USB ports. I turn on camera in play mode plug in and camera says DV IN computer says USB device not recognized one of the usb devices attached to this computer has malfuncioned windows does not recognize it OS Vista Home Premium running windows movie maker Any help would be appreciated Thank you
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by Guest on May 05, 2008
cannot download the tape
Posted by Guest on Feb 11, 2008
i have a regular firewire cable no funny adapters or anything and my vista run pc will not recognize it. canon says it doesnt need a driver.. Vista says it does. WTF?
Best Solution
posted on Jan 21, 2008
FixYa! (100)
hazydave
Rank:Master Master
Rating: 88%, 29 votes
Firewire works fine under Vista, but it's quite possible your USB to Firewire bridge doesn't have proper Vista drivers. You wouldn't expect Vista to include these, they would be installed from a disc that came with your adaptor. USB to Firewire is a questionable option at best... there are often problems with it. You may be better off with a PC-Card or ExpressCard solution, if the laptop is your only computer.
Also, when the camera says "DV IN", it's expecting video from the PC to be sent to it, it's not in capture mode. Most camcorders must be in either "play" mode, or a special "link to PC" mode in order to even be recognized by Windows (any version) as a video input device.
However, until you resolve the issue of supporting your Firewire device in Vista, nothing the camcorder does will be an issue yet. You should check the documentation that came with your USB to Firewire device, the driver disc, etc. for information on Vista support.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Vista and firewire 1394?:
I don't want to Accept this solution
Can you Help with these Camcorders problems?
Our camcorder is about 2-3 years old and all of the sudden...
i tried to play back a recording and the sound cuts in and...
Could I get a new manual for my Cannon ZR200 Digital Video...
quand je mets une cassette il s'affiche sur l'?cran:...
I have a Canon ZR200 that was purchased 3 years ago. It...
Loading problems.
Repair Service
Find Camcorder Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
