Question about Canon Optura Pi Mini DV Digital Camcorder
Can't eject cassette
Hello. I got a message to eject my cassette, but couldn't. Canon said to send it to them but when they got it they said they no longer fix the Optura PI. Thank you, Morty Sklar
5 Suggested Answers
  • 277 Answers
SOURCE: Optura Pi is eating tapes
hi from what i understand by "eat" is that the coil is popped out what it means is that the coil leader is misplaced and letting it to run free out of place this can be fixed by you if you will find what had gone wrong in that path (broken pin, cog etc...) and glue it back or fix the missing element in place good luck
Posted on Apr 30, 2006
SOURCE: Canon ZR900 cassette won't eject
I also found that I couldn't operate the camera in play mode. There is a section of the troubleshooting guide that says that the "The cassette compartment cover will not open or it stops halfway while you insert or remove a tape." According to the guide the solution is one of the following:
- Battery pack is exhausted. Replace or charge the battery pack (pg 17).
- Attach the battery pack correctly.
- Use the compact power adapter.
I removed the battery pack and unplugged the power adapter, then plugged in the power adapter/re-installed the battery pack and could get the camera to operate in play mode, but when I tried to eject the cassette the camera it would not only "not" eject the casstte but it also stopped operating in play mode. I'm going to try letting the battery charge to see if that helps.
Posted on Jan 04, 2009
SOURCE: eject mechanism not functioning
Once when this happened to me, I took it to a repair shop and they said it just needed to be cleaned. (Optura PI tape won't eject)
    Posted on Sep 01, 2010
    Rick Riggins
    • 1812 Answers
    SOURCE: Tape won't eject on Canon Optura 20 MiniDV. About
    This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
    My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
    If this response has been of any help to you, please be sure and give a positive vote for me on .
    Posted on Jul 30, 2011
    I too have same problem. The service people say that the whole deck has to be replaced which I do not believe. I think the pinch rollers have to be leaned and brake system to be adjusted/calibrated. The local mechanic would do that.
    Posted on May 11, 2013
    0 characters
    1 Points
    Eject cassette
    sounds like already rewound or tape is caught open and have a look!!
    May 15, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
    Canon ZR500 won't close cassette bay
    If your camcorder experiences an error, you may be presented with a ?Remove the Cassette? message. There are several reasons that this message may appear, but it is essentially a safety warning that is designed to protect the camcorder and/or tape from damage. The camcorder?s tape drive mechanism is made up of many precision components that, once damaged, may cause further problems if the mechanism continues to operate. When a problem is detected the safety mechanism is activated. The ?Remove the Cassette? warning and the camcorder?s safety mode may be activated by a variety of conditions such as: 1. Condensation is detected ? If condensation is detected by the camcorder, the ?Remove the Cassette? warning may occur. 2. Component failure ? If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder. 3. Sand or grit damage ? The camcorder?s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate. 4. Impact damage ? If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur. 5. Liquid damage ? If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation. 6. Improper videotape insertion ? If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual. 7. Damaged or defective tape ? If a tape becomes damaged, please discontinue its use. Operational Recovery Steps Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps: 1. Eject the videotape Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2. 2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry. If the "Remove the Cassette" message continues, the camcorder may require service. Please contact Canon USA's Tech Support Center at 1 (800) 828-4040. Technical support hours are Monday through Friday, 8:00am - 12:00 midnight; and Saturday 10:00am - 8:00pm (all times EST). Alternatively, if electronic support is preferred, please send your email to
    Aug 27, 2007 | Canon ZR500 Mini DV Digital Camcorder
    Eject cassette
    Sir it need to replace idler unit and servicing
    Mar 29, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
    Canon UC8Hi ejects cassette when it is inserted
    Canon UC8Hi: The cassette is not retained when the door is closed - it is ejected again immediately. IF it is not ejected, the ''EJECT'' light flashes.
    Jul 28, 2009 | Canon Video Cameras
    you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
    if nothing it will get rid of stress
    Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
    Loading a cassette
    having the same problem...when I put a new tape in it just ejects it right away!
    Apr 17, 2008 | Canon ZR200 Mini DV Digital Camcorder
    Remove The Casette Message
    THESE CAMERAS ARE PEICES OF ****!!!!!!!!!!!!!!!!!!
    I suggest that no body buys from cannon again!!
    I am suppose to record my sister-in laws wedding and BOTH of my ELURA 100's are displaying the EJACT TAPE message!
    "TEMP. FIX"
    This takes pateince however for me it works....When you get the EJECT TAPE mesage....eject the battery with the power on (thus the power will go off by means of the battery not being in camera) then slap the battery back in....and KEEP doing this untill eventually the camera will NOT DISPLAY the message and actual work.
    It may take up to 20 trys ....slap it in..slap it out...slap it in slap it out...BUt for me it works.
    If it appears to work but as you hit the RECORD button it beeps and displays the EJECT tape message again...Go back and eject the battery again and repeat the STEPS...but dont worry , that means your getting closer to it working.. LOL
    P.s- I hate CANON
    Sep 23, 2007 | Canon Elura 100 Mini DV Digital Camcorder
    Message reads eject. won't eject
    My camera did the exact same thing. I called Canon tech support and they advised to unplug power cord, remove large main battery, and remove smallbackup battery. The small back up battery is under a small door under the main backup battery. With everything disconnected, turn camera to "camera" and then to "vcr" and then to off. Wait a few seconds. Put everything back together and try to eject again. The tech said that resets all the mechanical parts. However, it did not work for me. They now want me to send it to them for a paid repair. I have done some research on the internet and this is a VERY commom problem and it usually costs about $150 to correct via Cannon. Many times the problem occurs again. I am very very frustrated. I pulled my camera out last night to get it ready as my wife is 9months into her pregnancy. Now, I have to send my camera away for 5-9 days. Really really upset.
    May 08, 2007 | Canon ZR200 Mini DV Digital Camcorder
    Canon Optura Pi Mini DV Digital Camcorder Logo
    51 people viewed this question
    Top Canon Video Cameras Experts
    Sheryl Bahr
    Sheryl Bahr
    Chris Phillips
    Level 1 Expert
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
