Question about GE (PSS26MSRSS) Side by Side Refrigerator
The letters hrs are blinking on the temp control panel
The letters HRS are flashing on the temp control panel and the motor has stopped running help
  • 90 Answers
Unplug for 3 minutes. Plug back in see what happens.
Posted on Jan 05, 2008
I just changed the oil and filter on my LX420 twin cam how do I get the blinking light to go out. Its a 2006
  • The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display.
  • The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time.
  • CHG"/"OIL"/TIME will alternate on the display for five (5) minutes after the meter reaches 50 hours.
  • While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five (5) minutes.
The display will also flash as described above for five (5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two (2) hours.( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...)
THE METER DISPLAY WILL RESET TO NORMAL AUTOMATICALLY, after the reminder maintenance time interval of two (2) hours. There is no method of manually re-setting this Service Monitor gauge.
May 01, 2017 | Cars & Trucks
Wheelchair runs fine after charging but only after 1 day 6hrs use it stops with a jerk and then controller lights start blinking.
Thank you for all the information, number one, charge with the joystick on for 12-14 hrs. there is a circuit in the joystick that can cause problems, in order to reset it you will need to charge it like this. The batteries will last longer if the batteries are charged every night that it is used during the day, also, instills good charging habits.
The blinking is a flash code, count the flashes, and refer to the owners manual for meaning. The joystick maybe failing or the controller or both. Motors may need to be cleaned out.
Apr 12, 2016 | Health & Beauty
My refrigerator/freezer is warm
If the motor is running but it's not getting cold then you may have lost coolant. Did someone clean the ice out with a knife?
Apr 28, 2017 | GE Profile PSW26P Stainless Steel Side by...
Ice maker/ water dispenser does not work. Letters HRS blinking on display. Temp control inoperable as well.
looks like a motherboard problem..if its a GE i think they had a recall on it and they will send you one for free
Dec 07, 2012 | Refrigerators
I have a GE Profile Artica, This am the unit stopped running and the adjust temperature displays were both blank. The letters hrs appear in the turbo cool display. I unplugged the unit for 1 hour and...
The "HRS" indicator is referring to hours and is related to the Quick Thaw or Express Thaw mode. If the Quick Thaw or Express Thaw feature is turned off then the "HRS" should disappear. However, it this is not the case most likely you will need to replace the main control board.
Dec 31, 2017 | Refrigerators
GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
Aug 21, 2009 | LG LRSC-26922 Side by Side Refrigerator
HRS flashing, nothing getting cold
Your refrigerator has a control board on the back behind a metal panel. Unplug and look at both sides to see if you see burn marks or loose solder. Go to this site and place model PS123NCRBV into the model search feature.That will take you to 13 similar models. The board on back is my first concern and the control inside will need to be looked at also if you find no problems on the back. The control board number is WR55X10656 let me know what you find, Thanks, Sea Breeze
May 19, 2009 | GE Profile PSI23NCR Side by Side...
Error code hrs is blinking, frig is not running.
Aug 29, 2008 | Refrigerators
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
650 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
