open it up, with the lens assembly there is a small preset, turn it
using a screw driver a little anti-clockwise..clean the lens with clean
cotton using isopropyl alcohol.. if not done, replace the lens assembly.. or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model.. assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!! open
up ur system cabinet and see if all the data cables n jumper settings
at the back of the drives (master/slave selection)..itz most
important..!! however, at the bootup (0.29sec) start pressing
briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del
as applicable)..glance in the standard settings if r detected
individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) :
Native/Compatible/Enhanced (as applicable).. see if ur device needs any additional driver or not, if so try downloading.. also try checking itz data cable for loose or faulty.. above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
Lenovo 41n5629 cd/dvd burner will burn discs, but will not play the burned dvd. It is a DVD+R DL...
(More)
Lenovo 41n5629 cd/dvd burner will burn discs, but will not play the burned dvd. It is a DVD+R DL disc. Thanks
my drive will play audio cds but wont read cd roms,why?i've tried the troubleshooter and it says its...
(More)
my drive will play audio cds but wont read cd roms,why?i've tried the troubleshooter and it says its working properly
samsung 22x DVD RW Black Model code-SH-S222A/ID BHT Month and year of manufacture-september 2008...
(More)
samsung 22x DVD RW Black Model code-SH-S222A/ID BHT Month and year of manufacture-september 2008 month& Year of import-October 2008 Purchase date-Invoice receipt-Jan 2009 Sir Ihave a problem occured my dvd rewriter(eye)please give details of warranty terms and conditions and warranty will get or not and explain that matter also
Sir's, I have a problem which is my tsstcorp DVDRW+- cannot read in both BIOS and windows. i dont...
(More)
Sir's, I have a problem which is my tsstcorp DVDRW+- cannot read in both BIOS and windows. i dont know what is the cause of this problem - burn cd the day before the dvd drive cannot read - i buy external Western Digital 1 TB harddisk and plug it via usb - no software installed so far My DVDRW can get power - still opening. I've done everything solution i've searched so far. - Delete Upper and lower filters in registry - uninstall / install ide - install cdgone registry patch - update windows updates - remove, clean and re-insert dvdrw drive - check device manager (not listed) Please, can someone help me with my problem. Thanks. here's my e-mail add, eugene.panti@exlservice.com
win vistas doesnt detect samsung dvd drive(octoedge). no icon on computer. doesnt detect in bios as...
(More)
win vistas doesnt detect samsung dvd drive(octoedge). no icon on computer. doesnt detect in bios as well.// pls help....
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
