Home | Samsung | HLN617W 61 in. Rear Projection HDTV Tel... | My picture when out and...
Samsung HLN617W 61 in. Rear Projection HDTV Television
Problem for Samsung HLN617W 61 in. Rear Projection HDTV Television
My picture when out and the green light came on
By ccnc3452 on Nov 07, 2009
My picture when out and the green light came on the front labled lamp.
i replaced the lamp and it is doing the same
Best Solution
posted on Nov 07, 2009
Very Helpful)
techman007
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 87 votes
Make sure you replace the door to lamp back on the set, as the unit will not work if the door is not reinstalled. This is a safety feature.
Make sure you reinstall it correctly and securely. If this still does not work, then you might consider replacing the ballast also. It is the usually called the lamp driver. Its used to light the lamp. When you cut on the set listen closely near the lamp housing for slight clicking sounds, this is an indication the ballast is trying to iginite the lamp and that its ok..
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung HLN617W 61 in. Rear
Questions and Unsolved Problems for Samsung HLN617W 61 in. Rear
Do you recommend Samsung HLN617W 61 in. Rear Projection HDTV Television?
Answer
Answer
Wont come on...it cycles 3 times and then the standby light comes on.
Answer
It is powering itself off.. It will turn back on ,but turns off again in a few minutes
Answer
have a 63" dlp model HLN617W and its making a grinding noise it turns on then shuts itself off... (More)
Answer
samsung flat screen keeps turning off...sound stays on...what is the problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung HLN617W 61 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
