How do i reset a canon PIXMA MP150 printer after the "waste absorber is full" message shows????
Comments:
Nov 07, 2009
- nope it doesnt work!!!!!11
Nov 07, 2009
- well unless i am doing it wrong!! it isnt working!!!
this is how i am doing it
with the printer off press the resume button, while continuing to press is press the power button .
leave the resume button and keep the power button pressed
while keeping the power button depressed, press resume twice. let go of all the buttons. then press resume 4 times. and finally turn off the printer!!!
is it right cause it isnt working?????
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection) 4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks 0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off) then turn it on again. this works. thanks.
Try these steps and let me know if worked or not.....
1. Turn off printer. 2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color. 3. let go button Resume/Cancel, continuing to retain POWER. 4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons. 5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!! 6. turn off printer by button POWER.
Thanks
Good luck
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MP150 All-In-One
I get an Error Code E3 - Paper Jam every second! page. If I print one sheet - it sometimes works...
(More)
I get an Error Code E3 - Paper Jam every second! page. If I print one sheet - it sometimes works without a failure code. If I want to print a second one, I get the failure message. If I cancel the print job, and wait some seconds, than the failure message disappears and printing is possible for exactly one sheet. After that same procedure. There is clearly NO paper jam. It must be a software problem within the printer. Can you help?
J'ai un Canon MP130 dont le voyant rouge s'allume par intermittence et quand j'appuie sur la touche...
(More)
J'ai un Canon MP130 dont le voyant rouge s'allume par intermittence et quand j'appuie sur la touche menu me donne le message"Invalid key/set. Que dois je faire puisque tout est bloqué
