Sony Playstation 3 (PS3) Console Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Icannot connect to the internet.when the system scans for an IP address it comes back saying failed. what to do?
Anonymous
Level 3:
  • Master 1,472 Answers
  • Posted on Nov 07, 2009
Anonymous
Master
Level 3:
Answers
1472
Questions
Helped
475082
Points
3527
Andersonmarc
In regards your issue connecting to the internet. You need to make sure that you are connecting your ethernet cable to the PS3 or connecting to a wireless router. If you are connecting to a wireless router double check your WEP/WAP settings. Also note if you have a USB modem to my understanding those would not work with the PS3 because you would not be able to install the drivers.
If you have any more questions let me know
Issken
Can't connect bluray to WBR1310
If the IP address is fixed in the BlueRay player, I would reboot the router or modem, which will reassign IP addresses. If one is in use, such as the Blue-Ray, whichever device is currently using it will get assigned a new IP address, assuming it too is not a fixed IP address.
How do I find the new IP address for the Zonet ZSP3611 Printer Server so I can set up my printer to work
An easy way would be to download and install nmap. For the IP address to scan, if your computer ip is say, 192.168.0.52 then enter 192.168.0.0/24 and select the quick scan. Whichever device comes back with an open port of 9100 is most likely the print server.
2helpful
Tried connecting my ps3 with the wi fi . It obtains ip address successful but fails to connect to the internet . It says dns error 80710102.
Go to the PS3 Network Setup, choose "Manual".
Leave the option for DHCP under "automatic", and under DNS servers, manually add:
208.67.222.222 or/and
208.67.220.220
These are the IP addresses for the Open DNS project and now your PS3 will be able to resolve internet addresses.
Cant connect to my wireless router and the 192.168.01 url entered doesnt help none
Windows XP
  1. Verify Ethernet adapter in device manger.
    1. Click Start > Search > Type in ncpa.cpl and press Enter.
    2. Click System>Hardware > Device Manager
    3. Click Network Adapters
    4. Verify adapter present, enabled, and no error messages.
    5. If error reported refer to OEM regarding error receiving
  2. Open the Network Connections window.
    1. Click on Start > Run > Type in ncpa.cpl and click OK.
  3. Double-click on the Local Area Connection icon.
  4. Click the Support tab.
    1. Ensure that Address Type: says "Assigned by DHCP."
    2. Ensure that the IP address is valid.
    3. If both are correct, click the Repair button and then skip to Step 9.
  5. If it does not say "Assigned by DHCP" click the General tab and then click Properties.
  6. Select "Internet Protocol TCP/IP" and then click on the Properties button.
  7. Ensure that the radio buttons are marked as "Obtain an IP Address automatically" and "Obtain a DNS Server address automatically" and click OK.
  8. Click OK again to close out of the Local Area Connection properties.
    1. Restart the system if any changes were made to the configurations.
  9. Right-click on Local Area Connection and select Repair.
  10. If the repair fails because the system is unable to flush the ARP Cache, the Routing and Remote Access service will need to be stopped and set to disabled.
    1. Click Start>Run>Type services.msc >Click OK.
    2. Double-click on Routing and Remote Access.
    3. Click the Stop button.
    4. Set Startup Type to Disabled and click Apply, then OK.
    5. Restart system.
  11. If the Repair fails to renew the IP address, ensure that all firewalls are disabled and try again.
  12. If it still fails, reset the networking protocols.
    1. Click Start>Run>Type CMD and click OK.
    2. Type netsh int ip reset reset.log and press Enter.
    3. Type netsh int ip delete arpcache and press Enter.
    4. Type netsh winsock reset and press Enter. (SP 2 or later)
    5. Type ipconfig /flushdns and press Enter.
    6. Restart the system.
Windows Vista
    2. Click Hardware and Sound > Device Manager
  2. Open the manage Network Connections window.
  3. Right-click on Local Area Connection and select Properties.
  4. Uncheck Internet Protocol Version 6 (TCP/IPv6).
  5. Select "Internet Protocol Version 4 (TCP/IPv4)" and then click on the Properties button. (Do Not Uncheck Version 4).
  6. Ensure that the radio buttons are marked as "Obtain an IP Address automatically" and "Obtain a DNS Server address automatically" and click OK.
  7. Click OK again to close out of the Local Area Connection properties.
    1. Restart the system if any changes were made to the configurations, including unchecking TCP/IPv6.
  8. Right-click on Local Area Connection and select Diagnose.
  9. If Diagnose fails to renew the IP address, ensure that all firewalls are disabled and try again.
  10. If it fails again, choose to "Reset the Network Adapter."
  11. If it still fails, reset the networking protocols.
    1. Click Start>All Programs>Accessories.
    2. Right-click on Command Prompt and select "Run As Administrator"
    3. Type netsh int ip reset reset.log and press Enter.
    4. Type netsh int ip delete arpcache and press Enter.
    5. Type netsh winsock reset and press Enter.
    6. Type ipconfig /flushdns and press Enter.
    7. Restart the system.
Windows 7
I hope this helps
2helpful
3answers
I have scanned for my internet and connected to it by typing in my wpa key. but when it comes to connecting the connection my ip address fail. do i type in my ip address manually? if so, where can i find...
First, make sure that DHCP is enabled.
Second, Don't use the pass phrase use the key.
  • For example, if you setup WEP to use a pass phrase like ROSEBUD, use the generated key code under it which would look something like AA34578E9...
Connecting Compex 28g to mobile broadband and home network
please check following points:-
1) IP address (some wireless AP's follows ip address such as 192.168.1.1 for AP and 192.168.1.2 for 1st workstation, 192.168.1.3 for 2nd workstation and so on).
2) check connection options in IE. it should be lan setting and detect automatic setting and use automatic configuration script(put IP address of AP)
3) if DHCP is enabled then obtain IP automaticlly
4) check for any WEP security options i AP.
5) user must have internet access rights.
6) if Static IP is Used please give gatway ip (your AP's IP address) and same for DNS IP address.
then restart your system and enjoy internet.
Failed ip address
your ip address should be activated by your isp
and then manually put it in the smart phone
Cant get xbox live connected
You have to make sure that your xbox knows your ip address and if your using wireless, your wep key. Your wep key should be on the back of your wireless router and you can make your xbox recieve your ip address automatically by editing the settings. you can edit settings by testing your connection. If your xbox does does not have your ip address, next to ip address it will say failed and next to that it says edit settings.
1394 LAN connection - no IP address
r u configure the ipaddress to the wireless router
4answers
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
