Question about JVC TH-C50 System
Sub woofer shuts off
Hi My subwoofer shuts down whenever it seems like there is a moderate to high level ov bass needed.I have turned the bass level to zeor and it still happens
  • Anonymous Apr 09, 2008
    If I turn my receiver up over a certain level (20 or so) my unit continually shuts completly down. I've had another receiver sent to me, but I'm assuming it is the subwoofer. What should I do?
  • 682 Answers
Please check sub cable first with another good one and then change sub itself.because it draw too much power.
Posted on Apr 06, 2008
1000 watt 2-channel Pyle PDGA240 Gear X Series
Make sure that the gain setting on the amp is turned up high enough on the sub's amp.
Aug 26, 2013 | Car Audio & Video
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
Mar 12, 2011 | Audio Players & Recorders
How do I adjust my subwoofer bass level for my kenwood kdc-138 car tereo You can download the manual from Kenwoods site. While the unit is in Standby mode, press the B.Boost button for a second or two. You should now be in the Menu. Select SWPRE. Now chose SW from the (R*/SW) options. The output of your CD player is now a dedicated sub woofer output. I hope this is what you meant. There are many settings regarding the sub woofer and generally the sound in whole. Getting the manual is highly advisable. dreamsystems.
Feb 08, 2011 | Kenwood Car Audio & Video
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
My sub woofer will stop working if i put the bass up to loud, ill have to turn my car off and on to get it to work again. What could be the problem?
Seems like your power amp for the sub woofer may be going into protect mode/thermal overload when you push the volume too much. Therefore it shuts down. I am surprised the speaker hasn't blown yet.
As far as turning car off/on to get it to work, it's as if your car is the power switch.
Amp and speakers may not be wired correctly, as you want to make sure your amp/speaker ohm measurements are within a specific range for the amp and speakers work together properly. You may have it wired for a 2 ohm load, and maybe your amp can't do 2 ohms all day long.
Apr 09, 2010 | Kicker Comp DC12 2-ohm Enclosed Subwoofer...
My car's sub is ''sub-par'' my expectations
Hello css42103,
You did not specify the impedance or the model of your Audiopipe replacement woofer but if it is the TS-V6 DVC 6.5", then the impedance of each voice coil is 4ohms. If you wired the coils in parallel, you now have a 2ohm load to the amp. At 2 ohms, the amp tries to produce more power, and even at moderate volume, can be driven into clipping causing distortion. Not good for the amp. Definitely not good for the woofer.
I'd try wiring the woofer coils in series and see if it stops cutting out.
Hope this helps.
Jun 01, 2009 | Car Audio & Video
Noise from speakers when playing basses
hello, check and see if cabinet has loose screws or if back panel is tight,bass can vibrate screw loose.good luck! also look for anything caught in the woofer causing the noise.
Jul 28, 2008 | Audio Players & Recorders
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
Just bought a new car. i removed old stereo and put in my kenwood kdc-w808. whenever there is base in a song it distorts i have to turn my base rite down to get rid of it. worked perfectly well in my old...
your speakers probably cant handle the bass.,also they are probably full range speakers ,so hwen the base hits at the same time a voice is singing the woofer is vibrating to produce the basss,there fore distorting the highs and mids {or voice}.You need to add a seperate sub woofer.And puyt capicitossr on the full ranfge speakers to limit the bass..Rating please. :}
Jun 16, 2008 | Kenwood Car Audio & Video
"cracking" noise
Your subwoofer is not capable of playing as loud as you want it to. That sound is the woofer reaching its limit. If you have any bass tone setting on your receiver set them to flat. If there are any other bass settings i.e contour, loudness boost etc turn them off. You can also try putting the woofer into a corner. This will increase the output. Closer to you would also be louder. Otherwise you need a sub with more output. Don't let the power rating fool you when you get a new one.
Aug 26, 2007 | Acoustic Research ARS108 Speaker
JVC TH-C50 System Logo
184 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
