Question about Brother MFC 420CN All-In-One InkJet Printer
Not receiving faxes
Hi
I got a new fax line installed just for this machine. It is for a business and I need it desperately. It sends faxes no problem to local numbers, but not others (i keep getting the busy signal), and I still cannot receive anything. It is set to easy receive, as it was not working on the other settings either. I thought it might be the line, as I had issues with it but the phone company engineers came to fix that. There is also no noise on the line when I plug a regulare phone into it.
  • 832 Answers
So if you have no noise, its a prob of the tele company not of the mfc!
Or did the tel company change to another tel standard instead of your former type?
You have to talk to the tel company to get that clear. Ask for the line standard bein g used (ISDN, normal, or a special tcpIp).
When you got the info call brother hotline of your country for support. They will help you with that prob.
Posted on Jan 05, 2008
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
I have a bother FAX4100E . It is newly installed. I can receive faxes but when attempting to send, no dial tone is immediatley heard. The fax always gets a fast busy. It is on the same line as my old...
Hi.
Check and eventually replace the phone cable.
The fax machine must be connected using a two-conductor phone cable such as the cable pictured below at the left:
Dec 13, 2010 | Office Equipment & Supplies
We have two fax machines hook up to one dedicated fax line. When we send a fax from wither machine it is not faxing to the phone we fax it only sends the fax for the second fax machine that is in our...
Yes, you must set up your fax machines like this: The receiving fax must be set to auto receive and the telephone line must be inserted in the "line" input. A line must then be connected from the "Tel" to the "Line" of the Transmitting machine, which must be set to "manual receive." This is not really a satisfactory way of doing things as you can't send and receive 2 machines on the same line together. A much better way is to have 2 lines. with a machine attached to each. Get the tel company to put "No answer transfer" on the line as an accesory. Give them the number of the fax machine that transmits. Make it "manual receive" Now you have a versatile system that you can also use the office telephone with.
Oct 05, 2010 | Brother Office Equipment & Supplies
Receiving faxes
Certainly not your fax machine problem.
The client needs to verify your fax number.
Oct 03, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Problem sending & Receiving Fax Imageclass D880 Canon All in one printer
#0018 indicates there was a problem with dialing, but it should show for sending faxes only. Since you can neither send nor receive faxes, and are getting a message saying "no signal", make sure that the phone line is still securely connected to both the L (line) jack on the machine and the phone jack in the wall. If it is, plug another phone into the accessory jack on the machine, and check to see if you are getting a dial tone. It seems like the machine is not able to communicate through the phone line.
Oct 10, 2008 | Canon imageCLASS D880 All-In-One Laser...
My model Kodak 5500 printer/fax
Just found your post and I'm having the same problem. Everything else seems to be working correctly. I can copy, scan, print and I THINK I can send a fax correctly, I should have called the person and made sure it arrived. However, I cannot receive faxes. I have an answering machine on the line, but it is not plugged into the Kodak Pinter, it is in another room. The answering machine answered the call, the FAX noise came across, but the Kodak Printer never picked it up and printed out the fax. I think I have all the settings correct, but the instructions are not very clear. Do you think I HAVE to have the answering machine plugged into the Kodak Printer? That doesn't make sense, but I might try it.
Feb 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Vonage vs Brither 4100
Have you called your own fax line and just listened to the fax hand shake? might sound simple but I have called fax lines before and it just rang, or it was busy or static, if your not getting a clear fax hand shake, then it is the phone line, if there is no answer you may have turned your fax to manual receive mode, If you don't know how it should sound call a friends business fax line and listen to it. I have actually gone out to businesses that reported send or receive problems just to call the line and listen to a disconnect message, that would make it difficult to fax.
Jan 13, 2008 | Brother IntelliFax-4100e Fax
Brother MFC 420CN All-In-One InkJet Printer Logo
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
