EliteGroup P4VMM2 Motherboard
Problem for EliteGroup P4VMM2 Motherboard
When i replace and upgrade my ecs p4vmm2 ram up to
By renol657 on Nov 07, 2009
when i replace and upgrade my ecs p4vmm2 ram up to 1gb..first it enter os but when i restarting im stuck with checking nvram"..im done with re installing the usb wire,reseting cmos..unplugging cards,replacing new cmos battery..replacing power supply..but it still stuck with "checking nvram"..
Solution #1
posted on Nov 07, 2009
Not Rated)
palaboy
Rank: Wiz
Rating: 82%, 1196 votes
disconnect the hard disk
put back your old RAM
turn it on, if computer boots , rejoice
now , take off your old RAM, put the new one, one by
one, if it don't boot
return the new RAM or have it replace.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Bat1956
Rank: Guru
Rating: 90%, 309 votes
Sounds as though your new RAM may not be compatible with the ECS.This is most certainly the case if the system boots correctly with the old RAM back in place.You may need to check the specs for this mobo on the EliteGroup website to find out what RAM is compatible.
Comments:
Nov 15, 2009
- Is there some information you are not sharing in this thread? Does your Operating System load and run after the NVRAM check? Also after giving a little more thought, NVRAM does not mean the plug in sticks, but stands for Non-Volatile Ram, which is part of your motherboard. A missing or misplaced motherboard jumper could cause this. Another clue would be if the time resets each time you reboot. That would indicate a problem with the CMOS battery, or the jumper next to the battery.
Was this helpful?
Yes
No
Popular Solutions for EliteGroup P4VMM2 Motherboard
Questions and Unsolved Problems for EliteGroup P4VMM2 Motherboard
Do you recommend EliteGroup P4VMM2 Motherboard?
Answer
Answer
Hi, i have a technical problem with one of the slots of the mainboard (grapic card). I like to buy a... (More)
Answer
how do i unlock channels on an ntl set top box?
Answer
Erroe asking me to return tray to normal postion and press reset buttun resume printing
Answer
i have anorthgate motherboard SV266M and i need drivers...video and netowrk etc etc
Answer
ela delisga varias vezes, parece problema da controladora
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For EliteGroup P4VMM2 Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14909
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
