i turned on the dryer tonight and w/in a couple minutes it made this loud sound - didnt sound like the drum was turning, just a loud sound. is that a belt problem that i can fix?
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Just installed new ciruit breakers and the dryer runs but still will not heat up. What should I...
(More)
Just installed new ciruit breakers and the dryer runs but still will not heat up. What should I check next
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
