Question about Sony KDF-E55A20 55 in. LCD Television
Lost all Power to TV
I was watching a game and just lost all power. Now it won't even power back up. In the bottom right corner there is a green light that turns straight to red and you get no sound or picture. Can anyone help?
  • 1 more comment
  • Fahdzilla Jan 06, 2008
    Okay, I now realize I should have posted my comment here and not as a solution....sorry!
  • amycp Jan 13, 2008
    Same problem...called Sony and they recommended me have a repairman come out and fix it. I'm willing to give it a shot myself if I have a little direction. Green light comes on and flashes then turnes to red and blinks six times...goes off for a bit then blinks six times again...and continues blinking red until unplugged. no sound ...no picture...nothing at all!
  • Anonymous Mar 23, 2014
    Plus we have lost our television remote
My TV did the same thing today. My red light blinks 6 times. Any help would be much appreciated!
Posted on Jan 06, 2008
    New Friend:
My tv powers on thwn after several minutes it powers off and the red light blinks 6 times...
Posted on Mar 18, 2016
Same thing with mine. Blinks 5 times
Posted on Jan 11, 2008
  • 43 Answers
How many times does the light blink red? It should blink so many times then stop then blink again. What's the sequence? This will help me determine where the problem is.
  • Dave Bies
    Dave Bies Jan 23, 2008
    If it is blinking 6 times then you most likely have an open thermal fuse which is usually caused by the lamp temperature getting too hot. You'll need to replace the sirocco fan on the optical block too because its usually clogged up with dust or this may reoccur. Unless you are familiar with removing the optical block I suggest you have a Sony ASC do the repair work. Good Luck
My hitachi 1999 tv turns on but off right away has flashing green lights in back
If the flashing green lights are on the circuit board each is tied to a voltage from the power supply----likely damage is there but a 99 may not be economical to fix in 2012.
Nov 04, 2012 | Hitachi Televison & Video
While watching a movie on my RCA tv. model #HD52w59, it just lost all power and wont turn back on and the green power light does not light up. there is powere at the putlet so i know its something with the...
check first loose or broken power cord. if ok, what you can do is look for the power supply board look for blown fuse sometimes due to voltage fluctuation the fuse get blow.
Sep 17, 2012 | RCA Televison & Video
Phillips
The main power regulator board is faulty. It should be replaced.
Aug 13, 2012 | Televison & Video
I have a WD62825, it lost power while watching. There is power at the plug in.
Is the grreen light on?..or can be switched on via remote? Plug it out then back in. Green light flashing? If so...you have lost input signal or the tv has reset itself to another input (non functioning). Use Remote to set input (via Net Command) to functioning signal. If the Green light NEVER comes on...it may be major system failure. Be sure remote is set to "TV"
Jun 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture but sound
do any lights come on with the TV?, like white vizio or orange vizio light. sounds like a problem with the power board. some vizio parts have lifetime warranties so contact vizio support and report your problem. if it is covered the service call is free. there is a green led light on the power board that should come on, if it is not on, you may have a bad power board. to see this light on the power board, turn off the lights in the room and view the tv from the back cover, power board is 3/4 way toward top in the middle of the tv
Mar 26, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
No power, lost power while watching tv
after picture is lost, does the screen remain lighting?
Jan 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
LOST ALL POWER
How many times does the light blink red? It should blink so many times then stop then blink again. What's the sequence? This will help me determin where the problem is.
Jan 05, 2008 | Sony KDF-E55A20 55 in. LCD Television
Lost power
The symptom you have needs to be looked at by a qualified technician for proper diagnosis. There are 9 LED`s ( 8 green, 1 red) in the power supply that light up under normal condition. These LED`s are used to help pinpoint the area of trouble. For example, when power is applied all LED`s but one lights up. The unlit LED may indicate the +27 volt source is bad. That will alert the technician to check components related to the +27v line. Since there are 8 green LED`s and 1 red, each having multiple suspects leads us to Mr Spock`s comment to captian Kirk." there are endless possibilities"
Nov 14, 2007 | Hitachi 50UX52B/53K 50" Rear Projection...
My widescreen tv...
I purchased a 32" ilo widescreen back in Oct. of 06. It worked great for about a month before I had similar problems as you're having. Suddenly my remote wouldn't work (except the power button) and none of the buttons on the TV itself would work (except the power button). I was able to watch movies but unable to switch the video over to TV mode. Very frustrating. The Walmart in my area wouldn't take the TV back. The only way I was able to get it fixed was by sending it to ILO's service center. (800) 216-5156. Fortunately less than three months had passed since my purchase plus I still had my receipt. Because of this they were willing to fix the problem free of charge. If more than three months have passed I believe they charge for labor costs but not for parts. Once I sent my TV out ILO had it fixed and back to me within three weeks. Luckily I had another TV around while I waited. I hope this helps.
Jun 04, 2007 | iLO 3200 32 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
1,063 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
