Home | HP | HP Pavilion dv6000z 15.4" Notebook Lap... | Screen says Ope...
HP HP Pavilion dv6000z 15.4" Notebook Laptop PC  PC Notebook
Problem for HP HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD...
Screen says Operating System not found.
By hvg51 on Nov 07, 2009
screen says Operating System not found.
Solution #1
posted on Nov 08, 2009
Not Rated)
almondz27
Rank: Apprentice
Rating: 0%, 0 votes
That just happened to me, and I'll tell you how I got my computer to boot up normally so I could create my backup disks.
When the computer reboots and you see the HP screen, hurry and press F10 to go to the setup screen. Go to 'Run Diagnostics' and the other tabs (I frogot which one) until you see the words 'return to system default'. Save and exit out of setup. The next time my computer boots itself the problem was fixed. I recommend taking it to a computer repair shop to see what the problem is.
Was this helpful?
Yes
No
Solution #2
posted on Nov 07, 2009
Not Rated)
muebe
Rank: Guru
Rating: 90%, 246 votes
Either the OS installation was damaged to where the computer cannot recognize it or the hard drive is damaged and needs replacement. You could try and use the recovery disc or operating system disc that came with the computer to try and repair or re-install the OS. If the installation fails then try taking out the hard drive and installing it in another computer to see if it is working or not. You should be able to re-partition and format the drive. If not replace the drive, If the drive tests good then it might be a hardware issue with the motherboard for the laptop.
Was this helpful?
Yes
No
Popular Solutions for HP HP Pavilion dv6000z 15.4"
Questions and Unsolved Problems for HP HP Pavilion dv6000z 15.4"
Do you recommend HP HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook?
Answer
Answer
the zoom on my computer is set at 100%, when I change it to 75% it won't stay at 75% and goes back... (More)
Answer
My HP Pavilion tx 1000 wont turn On. Is it the battery? Checked charger and have 18.86 DC volts...
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP HP Pavilion dv6000z 15.4"...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
