I am trying to install new RAM on my mother's Sony VAIO PCG-K25 laptop. It had two slots, each with 256MB sticks in them. I replaced these with 512MB sticks, and the computer wouldn't boot. It wouldn't even load the BIOS. So I put the original RAM back in, and it booted just fine. I experimented with several different configurations and learned the following:
a) It will only boot if both slots are filled.
b) It won't boot if both slots have the new 512MB RAM in them.
Any other combination of the new and old RAM seems to work. As far as I can tell, none of the sticks seem to be faulty. I checked multiple times to make sure that both sticks were seated correctly, so I know that isn't the problem. And this motherboard has a max of 2GB of RAM, so I know that isn't the problem, either. The laptop is currently running fine with one 256MB stick and one 512MB one.
I don't know much about RAM, so I am stumped. Any suggestions would be greatly appreciated.
Comments:
Nov 07, 2009
- I can't tell if the new ones are PC2700 or not (they don't say on them, and searching for the part number hasn't turned up anything), but they seem to work when not paired with each other. The system recognizes the proper amount of memory. I just can't seem to use them both simultaneously.Nov 07, 2009
- Unfortunately the computer is running Ubuntu Linux, so the offtek scan won't work.Nov 07, 2009
- Would a max capacity of 1GB matter, though? Is that 1000MB, or 1024MB?Nov 07, 2009
- As far as I can tell, it doesn't seem to matter which slot the RAM is in, and although I can't tell whether the new 512MB ones are PC2100 or PC2700, the information I've found online seems to indicate that it can use either. And it seems to use the new RAM with no problem, as long as there is only one stick of it paired with one of the old ones.Nov 07, 2009
- Here's the output:
# dmidecode 2.9
SMBIOS 2.3 present.
Handle 0x000C, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x000B
Error Information Handle: Not Provided
Total Width: 32 bits
Data Width: 32 bits
Form Factor: SODIMM
Set: None
Locator: SODIMM1
Bank Locator: Bank 0
Type: DDR
Type Detail: Unknown
Speed: 133 MHz (7.5 ns)
Manufacturer: N/A
Serial Number: N/A
Asset Tag: N/A
Part Number: N/A
Handle 0x000D, DMI type 17, 27 bytes
Memory Device
Data Width: 32 bits
Form Factor: SODIMM
Set: None
Locator: SODIMM2
Bank Locator: Bank 1
Type: DDR
Manufacturer: N/A
Serial Number: N/A
Asset Tag: N/A
Part Number: N/ANov 07, 2009
# dmidecode 2.9
SMBIOS 2.3 present.
Memory Device
Data Width: 32 bits
Form Factor: SODIMM
Set: None
Locator: SODIMM1
Type: DDR
Manufacturer: N/A
Serial Number: N/A
Asset Tag: N/A
Part Number: N/A
Memory Device
Data Width: 32 bits
Form Factor: SODIMM
Set: None
Locator: SODIMM2
Type: DDR
Manufacturer: N/A
Serial Number: N/A
Asset Tag: N/A
- Here is the output for the other two sticks of RAM:
# dmidecode 2.9
SMBIOS 2.3 present.
Memory Device
Data Width: 32 bits
Form Factor: SODIMM
Set: None
Locator: SODIMM1
Type: DDR
Manufacturer: N/A
Serial Number: N/A
Asset Tag: N/A
Part Number: N/A
Memory Device
Data Width: 32 bits
Form Factor: SODIMM
Set: None
Locator: SODIMM2
Type: DDR
Manufacturer: N/A
Serial Number: N/A
Asset Tag: N/A
- My mother and I both thank you for going to so much trouble.
