If it's the car picture with 6 little lines coming from it, that means rear light failure, I'd recheck the lights again and also check your signals and brake lights.
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Dell Inspiron 1525 PC Notebook
Hi,\r\nAt my dell 1525 the battery...
Answer
Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell... (More) Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works well, the battery is charging, the AC adaptor is working properly. What is happening? Stefan
It means to say that it is not getting enough power on the computer, check the power cable at the back of the tower and make sure the power cable is connected tightly. You can try taking it out and then putting it back in again to make sure it is connected firmly.
hi, if you have tried both batteries with the same laptop and they are giving you the same error code, then it could very well be a motherboard problem, both the batteries cannot be bad, what you can do is try these batteries on some other compatible laptop model to check if they work fine there. Also try swapping the AC adapter as in both case you might be using the same Ac adapter, try using some other good known AC adapter as well.
Further queries are welcome If you find my solution helpfull please do rate me
The monitor isn't getting a signal from the computer, which is why the power indicator goes orange. There are two possibilities:
1) The computer isn't operating correctly. It may not be starting up at all when you turn it on, and you have a "no boot" problem to solve, or
2) The computer is working properly, shows all the signs of normal startup (hard drive activity, Windows startup sound from speakers, etc.). but video isn't reaching the monitor. There may be a problem with the video card (or on the system board if it's integrated video). Or the monitor itself is bad and not detecting the video. You can test this by connectng a known good monitor.
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
