Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Problem for Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Diswasher will not start
By gtrible on Nov 07, 2009
Diswasher will not start I had been running it and pushed the start button and it will not run. Checked to make sure was shut tight and if electricty was on,
Best Solution
posted on Nov 07, 2009
Very Helpful)
rogrrabbit
Rank: Guru
Rating: 90%, 226 votes
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool 24 in. GU3200XTP
Questions and Unsolved Problems for Whirlpool 24 in. GU3200XTP
Do you recommend Whirlpool 24 in. GU3200XTP Built-in Dishwasher?
Answer
Answer
my dishwasher will not come on at all. The power is good, but nothing happens when I close the... (More)
Answer
Dishwasher stopped in mid cycle, everything went dead, curcuit breaker OK.
Answer
whirlpool dishwasher gu3200 pots and pans light flashing
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool 24 in. GU3200XTP...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
