No heat I have a 6 foot singer electric heater and has quit working. It is a 240 wiring and power to unit and thermostat has been changed and still doesn't work
  • 3 Answers
You may try checking the polarity of the element and mabie check your thermal disks for a bad one. Hope this helps
Posted on Jan 05, 2008
6ya staff
SOURCE:
Controlled by wall thermostat. Heater has two wires, both ends, white/black
so my question is this is electric heat? it sounds it so next question is it 120 or 240 volt. but you will have a black and a white wire from your electric panel feeding the line side of the thermostat then another wire loading from the t-stat to the electric heat. i hope this helps. Tom the electrician
Apr 04, 2015 | Heating & Cooling
Has power to the heater but is not heating
depending how good your are with electric and brave. I would take a jumper wire and jump around each switch or control unit 1 by 1, but remember you are working with 240 volt and probably 20 amp circuit. might be temp thermostat.
Jan 17, 2014 | Broan-NuTone 198 Baseboard Heater
I awoke to no hot water, my heater is three yrs old and i just changed my upper and lower element and upper thermostat, still no hot water then i checked to see if i was getting power and i am, is there...
Your water heater has 2 elements so its 240Volts.
1) If breaker is delivering power on one leg of the 240Volt circuit, then water heater can appear to have electricity, but tank is receiving 120V. Both 120Volt legs are needed to complete the 240V circuit. Double check for 240Volts.
2) Review electric Load.
Water heater label shows wattage of tank.
If tank is 4500Watts for example, you installed 3500 or 4500 watt elements.
With 5500 Watt elements you need 30 amp breaker and orange-colored 10 gauge wire
With 4500 Watt elements you can get by on 20 amp breaker and 12 gauge wire up to 75 feet away.
3) Check ECO red reset button on upper thermostat. If reset is tripped, then ECO is reading high temperatures. Suspects at this point are defective upper thermostat, shorted wire or bad lower element.
4) Also note that insulation and cover must be re-installed over thermostat. Thermostat reads temperature through wall of tank. If outside air circulates around thermostat, that can cause a mis-read and cause tank to overheat and ECO trips.
If you don't want to test the heater, replace both thermostats for about $25. Return the upper thermostat for a refund. Then see of problem persists.
Here's what I would do.
1. Check breaker for 240
2. Check water heater for 240 across 1 and 3 screws on upper thermostat
3. Note wiring and breaker size.
4. Note label on side of tank.
5. Look at end of new element to see wattage printed on each element. Look for sings of high heat and burning. Tighten screws on elements.
6. Check ECO reset button. Look for high-heat and burning. Tighten screws on thermostat.
7. Test upper thermostat as follows:
http://waterheatertimer.org/images/Electric-diagram-water-800.jpg
Test left-side #1 screw to right-side middle #4 screw. Test should read 240V at all times. If not, then ECO is tripped, thermostat is bad, or electricity is OFF
8) Water heater is cold so upper element should be ON. Test upper thermostat.
Test right-side #3 screw to left-side bottom #2 screw and it should read 240V
Test right-side #3 screw to right-side bottom #4 screw and it should read 0 volts
8. If upper thermostat checks out. Test upper element for 240 across both screws. If upper element does not read 240 when water is cold, then element is bad or there is a shorted wire between element and upper thermostat.
How to test element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
9. Do a full troubleshoot on electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Dec 07, 2010 | General Electric GE SmartWater Household...
We have a Bosch WTL 6301 , as the heater not working so what I can do , I have test the Heater and its Ok but no electric comes to it
Could be a faulty thermostat/s, or the timer control unit could be faulty.
The power goes to the thermostat/s before going to the heater.
Mar 09, 2010 | Bosch Axxis WTL 6106 Electric Dryer
My dryer is no longer heating up and it does not time out, what parts would i need to fix the problems?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug
Whirlpool style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
I wire a 240 heater using 12/2 wire making both the black and white hot at the breaker to a thermostat using the wire diagram on the website as the guide. I have power to the switch and when I turn on the...
You should have the black going to 1 breaker, and the white going to an adjacent 2nd breaker.
Check that you have 240 VAC to the thermostat, and that the breakers are fully set.
If you have 240 VAC to the stat, check that 240 VAC is being powered to the heater.
Let me know what you find. (I am assuming the heat strips are good.).
Dec 14, 2009 | Fahrenheat Electric Hydronic Baseboard...
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
Connecting 240 volt singer baseboard heater
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
Nov 28, 2007 | Heating & Cooling
Heating & Cooling Logo
221 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
