My 2006 Mitsubishi WD-65732 65" DLP has sound but no picture. After hearing the sound with no picture for about 1 minute the sound goes out and the Status light turns constant red. The error code I get is 61. Help! Getting sound and no picture has happened to this set before but, by unplugging it for a while and plugging it back in got a picture again but that is not working this time. Also, does anyone know if one can find all the error codes & what they mean posted somewhere on the net?
i have a mitsubishi wd-65732 and i need the whole screen to be replaced and the bulb, how much will...
(More)
i have a mitsubishi wd-65732 and i need the whole screen to be replaced and the bulb, how much will it cost for each and where do i go to get it fixed
am aware of the connector problem on the sensor(i.e. airway blocked message and shut down) .What...
(More)
am aware of the connector problem on the sensor(i.e. airway blocked message and shut down) .What causes lamp failure if the tv is not really overheated..have replaced 3 lamps and gona do #4 today??? This is model 65732..have read the blogs on repairing the connectors and will do this today while replacing the lamp. Also tried small fan blowing into the air vents to no avail..the lamps last about 6 months with the tv off most days, just used in the evening...is this normal life span for a lamp????
I would like to know how to safely remove the front of my television & clean the mirror due...
(More)
I would like to know how to safely remove the front of my television & clean the mirror due to a moth that is dead and the siluoette can be seen on the screen I do not know how it got inside my TV but it did and I do not want to damage my tv trying to remove it I have a 65" Mitsubishi DLP Model# WD-65732, Serial# 111440, Manufactured November of 2006, Please help!
Any available repair how-to info on replacing/soldering capacitors on DM Board for a Mitsubishi...
(More)
Any available repair how-to info on replacing/soldering capacitors on DM Board for a Mitsubishi WD-65732?
