Home | GE | Profile 26.6 cu. ft. Side-by-Side Ref... | Refrigerator is warm in ...
GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Problem for GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with...
Refrigerator is warm in top half only
By jvh_joeris on Nov 07, 2009
refrigerator is warm in top half only
Comments:
Nov 08, 2009
- TFX28PPCG WW
Clarification Request
Posted by aasc on Nov 07, 2009
It sounds like the freezer fan is not blowing to the refrig . Need your model number to help you .
Best Solution
posted on Nov 07, 2009
Very Helpful)
Sea Breeze
Rank: Guru  GE Refrigerators  Expert
Rating: 90%, 731 votes
This will need to be checked out soon. If you are interested in doing this yourself you will need to let me know. Hopefully your refrigerator is only having a problem with a bad defrost heater and defrost thermostat. I will not say that I have a simple answer on the problem but the most likely reason is a burned out defrost heater. I will be back soon with everything you will need to consider,
Comments:
Nov 07, 2009
- First thing I want you to do is open the freezer and look at the rear back panel to see if there is a layer of frost or ice beginning to build up. If yes unplug the refrigerator and remove the panel and begin by defrosting with a hair dryer or placing a bucket of hot water inside,close door and wait until ice melts. If after the ice is gone look at defrost heater to see if burned out. Will be easy to see because the element is inside a set of glass tubes. If you need to replace the defrost heater I recommend you also replace the defrost thermostat. part numbers ClickHere=> WR51X10042 Defrost Heater and the WR50X10054 Defrost Thermostat If you see these parts are not needed let me know because we then will need to check the control board, evaporator and condenser fans. Sea Breeze
Nov 08, 2009
- AASC That is my wife on the left thanks, I know I'm old!..Sea Breeze
Nov 08, 2009
- Artica and Profiles all fall in the same category from 22 cubic feet up There are a few other refrigerators that GE makes that uses the same basic mother board and thermostat controls. There are some that come with manual thermostats but all are subject to mother board failure due to something simple like a condenser fan going bad. If a fan stops and starts on these models it will take out the motherboard. If the fan is not replaced if that was the reason for the first board the the new mother board will also be damaged. Here is a site that will focus on the models with a test technical sheet and a link to the service manual. The manual does not mention the 26.5 cu. ft. but it's the same parts just bigger. Some mother boards are a little different due to the different features on the refrigerator. These models need a good surge protector on the outlet where its plugged in. A small surge in power gets the board also. Some people call them Muthaboards for that reason. Here is the page=> APPLIANCE PARTS and TECHNICAL SERVICES
Nov 08, 2009
- Thank You Very Much For the Rate! I do not want something simple to damage that board and those refrigerators are good refrigerators just have the weakness in the board. Like I mentioned before something simple like a bad fan can trick some of the best technicians. I once made 4 trips and finally caught the condenser fan stopping after running a while. Most technicians have a time limit and will not spend the time to check things thoroughly. So insure those things that I listed are caefully looked over closely, You will find my contact information. I'm listed here but seems the feature is overloaded at the moment. If you need my help and feel like this is something you want to do, just let me know, Thanks, Sea Breeze
POINT and CLICK APPLIANCE REPAIR
Nov 10, 2009
- I see you posted a different model number after your post. The parts about the heater and defrost thermostat part number changes and you are lucky to have a defrost timer inside the fresh food compartment. That will be the most likely cause with that part click here=> WR9X489
If you have any problems contact me, Thanks Again, Sea Breeze
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
aasc
Rating: 93%, 535 votes
Sea breeze could be right .
Sea breeze , you are beautiful !!! Is that your dad on the right ?
Was this helpful?
Yes
No
Popular Solutions for GE Profile 26.6 cu. ft.
Questions and Unsolved Problems for GE Profile 26.6 cu. ft.
Do you recommend GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW?
Answer
Answer
no water to ice maker. I think water shute is frozen, because I can get water to the door. I have... (More)
Answer
Ice maker in our GE profile refrigerator is not making ice. The water dispenser works. The green... (More)
Answer
ge profile refrig pss265sgpa ssfg 409236 has a leak in the icemaker and now am having odor when I... (More)
Answer
GE Profile Refrigerator (PSS26MSWASS) The ice dispenser intermittently dispenses ice. Checked... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile 26.6 cu. ft....:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
