Question about Mitsubishi VS-60111 60" Rear Projection Television
Mitsubishi VS-60111 video blink
Every few seconds the video blinks to black screen but the audio remains perfect. Picture quality is perfect when functioning.
  • beachtileman Jan 05, 2008
    Solder appears to be good and there is no noise appearent near the high voltage circuits during the flashes
  • beachtileman Jan 06, 2008
    No service manual but I believe that I can get one online. For the past few hours with the back open it has only blanked out a few times ane I have not noticed it for awhile now.
  • Mitsubishi Master
  • 8,617 Answers
I would check for Bad solder joints around the flyback, and the verticle and horizontal yoke plugs for starters. Lower your volume and listen if you hear the high voltage come back up when your video comes back up. Let me know what you discover when you check the solder joints.
Posted on Jan 05, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jan 05, 2008
    More likely is a bad solder connection on the vertical output IC or at one of the yoke connectors. Trace the deflection yoke connections back to find a small IC on a heat sink, usually with a location number in the 400s. Resolder the connections at the yokes and at that chip.
  • Sonny Berry
    Your problem is most likely in the vertical sweep circuit. This is a protection built into projection TV set when they lose the vertical sweep so the three picture tubes do not get burn lines in the face of them. This problem is a bad b+ supply capacitor that feeds the voltage to the vertical IC in the sweep power supply, and or the vertical IC could have gone bad. If the vertical is working, you may have a video problem.Do you have the service manual so you can check out voltage supplies at various test points in the verticle and video circuits?
  • Sonny Berry
    Sonny Berry Jan 06, 2008
    If it seems to be doing better since you've been looking over the components. That tends to make me more convinced its solder related. You may have to look it over really good with a magnifying glass as alot of times there super hard to see little cracks show up under magnification.
Tv mitsubishi vs-60111
Was there a power failure? unplug unit for a min and plug it back in. hold power button til unit turns on. If it still flashes you may have a power supply problem inside the unit.
Apr 08, 2014 | Mitsubishi VS-60111 60" Rear Projection...
Where is the location of the capacitors on the dm module for my mitsubishi model 60111? Please show an image of location.
Your model the VS-60111 is the V20A chassis which doesnt have a DM board. I can assist with the issue but will need to know what the set does when you pug it into the electrical outlet and also what happens when you press power? Any lights? if so what color and is it solid light or blinking? Please respond to this same post for further assistance.
Apr 03, 2013 | Mitsubishi WS-55819 55" Rear Projection...
Read that this is a common problem...I have a VS-60111....when i turn it on it clicks then goes right back off....I used to manage a service department for a place called Conns. Sell appliance and...
You cannot be sure of the problem unless you try the error code operational check. Here are the instructions for doing it
Turn off the tv from the remote and unplug it. Plug it back in . Press and hold the menu and Device/Input buttons on the front panel of the tv for 5 seconds. The LED will blink a certain number of times, pause for half a second followed by another series of blinks. Count the number of blinks before and after the pause so that I can tell you what the problem is.
May 13, 2011 | Mitsubishi VS-60111 60" Rear Projection...
I have a Mitsubishi VS-60111 TV and the colors are messing up. When I go into the Convergence screen, the blue line is warped and will not let me move it back itno place. What do I need to do?
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya
Or goto the site for the parts and instructions on how to fix it yourself.
Jan 28, 2011 | Mitsubishi VS-60111 60" Rear Projection...
Tv turns on for about three seconds and then turns
here's a simple test, tap the unit several times and see what happens.but, whatever happens, call a tech,it has already faulty components inside.
May 14, 2009 | Mitsubishi VS-60111 60" Rear Projection...
My tv blinks from regular picture to a black screen continuously.
your tv is on the blink.
remove the back panel of set
on the crt pcb board you will find a wite or black pot.
turn it up or down while set is on this is the G@ voltage ajustment.
you might get 3 monts to a year of extra life from your pictor tube by doing this.
Dec 23, 2008 | Sony KV-32S42 32" TV
Flashing Tv screen
Turned out to be a problem with my dish receiver. Found out by attaching a separate DVD unit to the TV, and it didn't flash. I then realized everything ran through the dish receiver. Called them, reset ( by unplugging for 90 seconds) and all was well.
Jul 20, 2008 | Mitsubishi VS-60111 60" Rear Projection...
Black square in middle of TV
Turn off the closed caption on the TV set. Someone has turned on that feature. Good Luck
Jul 12, 2007 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi VS-60111 60" Rear Projection Television Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
