Zanussi Front Loader washing machine - FLE1216W Bad odour coming from inside the drum. Smells like stagnant water or could be sludge. Tried everything, filter is clean, ran a clear boil wash, and bleach rince which worked for a while now it's back again.
I had the same prob -
This was resolved by flushing sump tubes after disconnecting them. the small one was silted up and stank like sewage.
Now have a bleebing which could be related to water levels...
doh!
Posted on Feb 11, 2008
Zanussi FLE1216w Repair Manual
Hi, my zanussi fle1216w is skipping the fabric softener stage of the cycle. I've cleaned the dispensing drawer and the surrounding areas, even put on a boil wash in case somethihg was gunge up or visits the Zanussi Owners Manual.
Mar 22, 2012 | Washing Machines
Hello - I have a Bosch Classixx 1400 and it smells bad! What may be causing this? I have emptied the black tube with water in adn I have unscrewed the plug on the right and water came out of here but the...
Hi.
The smell will be coming from inside the drum as you summised.
It is probably caused by the drain in need of cleaning, or more likely a build up of dirt and scum on the door seal cased by doing too many low temperature washes.
Check the seal carefully and if it is stained black, then the only real solution is to replace the seal, and do more high temperature washes
Jan 16, 2011 | Bosch Washing Machines
The smell that comes from this machine is terrible. My clothes also smell bad. I wipe out the seals rubber around door and leave the door open for at least 30 min. After each wash. I also take clothes out...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jun 19, 2010 | Samsung WF337AA Front Load Washer
My machine smells at the door where the rubber seal is . what can i do to get it to stop smelling so bad?
Jun 18, 2010 | LG WM2688H Front Load Washer
The washer smells bad. We have taken it apart and cleaned between the tubs. The agitator turns in both directions
May 21, 2010 | Whirlpool LSQ9659PW 2 SPD 10 CYC 4 TEMP 5...
Why does my front loading washing machine smell bad and make my laundry smell sour?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 19, 2010 | Kenmore Elite 45986 Front Load Washer
Water left in tub at end of load smells bad you don"t see water but can hear at a turn of the tub by hand.
May 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My washing machine smells sour and I don't know how to cure it.
I used 2 quartz of Clorox bleach running a full load without clothes. After that the odor has gone for good. Try that.
Oct 05, 2009 | GE WHRE5260E Top Load Washer
Bad Odour from Drum
The smell that you are getting is stale soap build up between the inner drum and outer tub caused by frequent use of low temp progs. to remedy this problem do a 90 degree prog with some old towels this will melt the old soap, if you still have the problem add some soda crystals and do the 90 degree wash again failing this your drain hose may be to low causing dirty water from the sink to back drain in to the w/m, raise level of drain hose. hope this is of some help murdozzz
Apr 13, 2007 | Zanussi F1045W Front Load Washer
Washing Machines Logo
194 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
