Kenmore 73952 / 73954 / 73956 Gas Dryer
Problem for Kenmore 73952 / 73954 / 73956 Gas Dryer
Dryer is making noise when it is running,i am
By hippie1972 on Nov 07, 2009
dryer is making noise when it is running,i am trying to get it apart to find problemi cannot grt it apart
Solution #1
posted on Nov 07, 2009
Not Rated)
milleraba
Rank: Wiz  Washers & Dryers  Expert
Rating: 83%, 459 votes
I'm sorry you are having trouble opening your dryer. As I understand it, you have a noise when the machine is running and you want to fix it. I want to help you with this.
Please look for any screws that may enter from the top into the machine. Then, pop the top, literally, pry it apart from the bottom and it will open. Remove the front ... spring clips or two screws, and maybe both. Be careful with the wires that go to the door switch.
As you remove the front, the drum will fall free from the front bearing. It is probably this front bearing (made of felt normally) that is making the noise you hear. You can clean it or probably replace it. I suggest you replace the drive belt at this time as well since you are opening the machine.
You may be able to refurbish the felt bearing but you have done a lot of work to get to this point, replace it. Get parts from a FixYa.com advertiser or a local appliance parts place or visit www.repairclinic.com
I hope this comment helps you to repair the noise you hear from your machine.
Thank you for posting your question on Fix.Ya.com
a
Was this helpful?
Yes
No
Popular Solutions for Kenmore 73952 / 73954 / 73956
Questions and Unsolved Problems for Kenmore 73952 / 73954 / 73956
Do you recommend Kenmore 73952 / 73954 / 73956 Gas Dryer?
Answer
Answer
kenmore dryer model 110.96585100 will not start.No sound, no clicking, no nothign when start button... (More)
Answer
1/4 inch belt for Kenmore Gas Dryer 70 Series, part number begins with 339.......
Answer
dryer not fully heating it is getting warm but that is itblk
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 73952 / 73954 / 73956...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
