Linksys WRT160N Wireless Router
Problem for Linksys WRT160N Wireless Router
I am running qwest DSL through a Linksys wrt160N
By kevin_bur852 on Nov 07, 2009
I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above the router and I attempt to connect in the basement directly below the router. It sometimes will connect but then goes down right away.
the DSL modem is an Actiontec GT701R.
thank you in advance to anyone who can help me. QWEST IS NO HELP! THEY SIMPLY SAY WE DON'T SUPPORT LINKSYS!
Solution #1
posted on Nov 07, 2009
Not Rated)
Geekman
Rank: Guru  Linksys Computer Networking  Expert
Rating: 85%, 1725 votes
If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
The wireless card in the computers will show a low signal strength.
Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
Was this helpful?
Yes
No
Popular Solutions for Linksys WRT160N Wireless
Questions and Unsolved Problems for Linksys WRT160N Wireless
Do you recommend Linksys WRT160N Wireless Router ?
Answer
Answer
I cannot connect brother MFC-7840w to my network
Answer
Don't buy this model it sucks! Why doesn't someone start a class action suite against Cisco if they... (More)
Answer
i have a slingbox on a new wrt160n and i cannotview tv remotely i need to manually change settings
Answer
I cannont connect my Brother MFC-9840W wireless printer to my Linksys WRT160N router. It says... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Linksys WRT160N Wireless...:
Top Router Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
