Home | Western Digital | 250GB MyBook External USB 2.0 250 GB Har... | My Western Digital MyB...
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
Problem for Western Digital 250GB MyBook External USB 2.0 250 GB Hard...
My Western Digital MyBook turns on but pc doesnt recognize it!
By wrx_023 on Nov 07, 2009
My external HDD Western Digital MyBook turns on when i plug in the USB cable but my pc doesnt even recognize it as plugged. And i know the usb ports works. I have restarted my pc, the HD and nothing. I have tried different cables too but nothing seems to work. The weirdest thing is that i was using it 20 mins ago, turned off my pc, turned it on and HD is not there. I resat everything and HD doesnt show but it turns on, although it doesnt spin. PLEASE HELP!!!
Solution #1
posted on Nov 07, 2009
Not Helpful)
armstrng
Rank: Guru
Rating: 87%, 64 votes
Have you tried it on another machine?
When you eject your usb devices are you using the proper methods?
Hope this helps.
Was this helpful?
Yes
No
Solution #2
Not Rated)
bob_computer
Rank: Guru  Western Digital Computer Accessories  Expert
Rating: 87%, 1187 votes
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Was this helpful?
Yes
No
Popular Solutions for Western Digital 250GB MyBook
Questions and Unsolved Problems for Western Digital 250GB MyBook
Do you recommend Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive?
Answer
Answer
MAC TimeMachine no longer sees WD passport 250GB''The storage location for TimeMachine Backups can't... (More)
Answer
i have a western digital 250gig hard drive that i need to reformat and i keep getting a box that... (More)
Answer
My portable hard disk shows an error msg windows explorer has stopped working while opening
Answer
I have a Mybook Studio connected to my iMac and linked to Time Macine for back up. I have just... (More)
Answer
i can see the disk in my computer i have a lot of files on the drive but it does not allow me to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Western Digital 250GB MyBook...:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14723
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
