My maytag neptune washer will come on and then turn itself back off. maybe 10 seconds-maybe a coupleminutes. If you hold the start button down it will run
There is a door locking unit that should lock when you press go. This must have failed. It lives just under the lid in the middle at the front. It is thermal piston, when you press go it gets power and extends. When it hits a micro switch that tels the washer the door is shut and allows it to continue, else it shuts down. To get at it you have to take the front off, leave the door on.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune MAH5500B Front
Maytag Neptune MAH5500 leaks in the front left corner. It always seems to hold water but it just...
(More)
Maytag Neptune MAH5500 leaks in the front left corner. It always seems to hold water but it just began to leak. It is not leaking from the door.
Is there a remedy to overide the door open switch so I can leave the door open and be able to turn...
(More)
Is there a remedy to overide the door open switch so I can leave the door open and be able to turn off the light and control panel? This will let me leave door open to reduce mold from forming.
