Re: High pitched buzzing sound. This sound is real high...
Sounds like the flyback # 270125 you can get a replacement at www.tvrepairworld.com which includes the CD with instructions and the two associated Capacitors.
DSLReports
Oct 3, 2009 - 30 posts - 7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
? 1:43 https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
Is the microphone live? If so, what you're getting is called "acoustic feedback". Any room sound gets in the mic, gets amplified, comes out the speakers, and then gets picked up by the mic again. Louder and louder until you get to the maximum your system can do.
The solution is to turn it down. . . until it stops.
I notice that some of my cell phone wall chargers make a high pitched ringing sound, not that loud though. I think cheaper internal electrical components are the culprit. (Opinion)
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Is this buzz from the speakers?
Is this buzz from the set itself when the sound is turned down?
Is this buzz a low pitch sound?
Is this buzz a high pich sound?
Does this buzz vary in loudness with the volume control?
Does this buzz change in level from time to time?
You should post the details and the circumstances of use in order to give some idea of the conditions.
I wonder if there is enough air circulating around your equipment??
My DVD recorder makes a sound unless I open
the doors on the cabinet that contains all of my equipment.
The cable company says it is a fan to cool down the units.
I was going to suggest the low voltage transformer, but when you said it sounded like it was coming from the left side, that seemed odd.
I have a stock transformer here I keep for test that is loud, but it works. Odd, eh?
By high-pitched, you mean it is not that same frequency as when it's cooking?
Is the tone near or the same as the beep you hear when you press a key?
Please post a little more information so we can help better.
