Yes you have a motor fault and need to replace the motor. This is a difficult job. You need to remove the back panel of the washer to access the motor.The motor is the only thing that will draw enough amps to flip the breaker when it shorts out. The motor probably over heat closer to the end of the cycle and shuts down. Yes motor usually last allot long but sometimes they just fail early.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 45986 Front Load
from a power surge i am pretty sure I have a circuit board out. I have a whirlpool duet GHW9150PW0...
(More)
from a power surge i am pretty sure I have a circuit board out. I have a whirlpool duet GHW9150PW0 front load washer. There is a main c board in the back and thenm the one behind the control panel. how can I tell which one is out , or what is the more likely one?
i have had a kenmore elite smartwash for 2 years -- I do not have it stacked. I just started a load...
(More)
i have had a kenmore elite smartwash for 2 years -- I do not have it stacked. I just started a load and after 10 seconds or so, I received the F20 error code. what should I do?
Our Kenmore Elite HE3T washing machine isn't spinning clothes. It makes sort of a groaning sound...
(More)
Our Kenmore Elite HE3T washing machine isn't spinning clothes. It makes sort of a groaning sound when it is supposed to be spinning. There is a small amount of water in the bottom of the washer and the clothes are wet. There has been an F02 code and we followed the instructions to check the drain hose. What is likely the problem? Can I fix it, or will it require a repairman?
