Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Problem for Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
What is the carberator adjustment on the two
By jonathanrifk on Nov 07, 2009
what is the carberator adjustment on the two knobs? just under the phillips screw (idle adjustment) there are two small knobs that I have messed with to get it running better. From full in how many turns out should it be on both. What are they? low end?
Thanks, Jon
Best Solution
posted on Nov 07, 2009
Very Helpful)
dontbother10
Rank: Guru  Tools - Building & Power  Expert
Rating: 98%, 832 votes
Jerry the EPA has asked me if I know where your shop is located. They have a few things they would like to discuss with you.
Lou
They said they were bringing the IRS to drive the point home. Never mind they remembered they can get anything they need from FixYa.com.
Comments:
Nov 07, 2009
- Starting point for both H & L screws 1.5 turns CCW from lightly seated. To lean will cause piston and cylinder failure.
Nov 07, 2009
- CW is leaner, CCW richer.
Nov 07, 2009
- The L needle controls how smoothly it runs at low speed and how it accelerates to full throttle. The H needle controls how well it performs at speed and should be set for cut performance not best sound with no load. All adjustments are made using a fresh fuel mix at a proper fuel/oil ratio (I recommend 50:1 = 1 gal super not regular gas to 2.6 oz quality 2 cycle engine oil),at the elevation it will be used, and a clean air filter, with the bar and chain installed and properly tensioned. The T screw is throttle or idle speed. HTH
Lou
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
mrfixit-jerr
Rating: 94%, 7475 votes
hello sir,, now there are two types of carb.adjustment screw covers,the old one where there are plastic over the screws,simple remove the plastic covers with a pair of needle nose pliers or cutting off,,,second are the new ones that are above the adjustment screws,which you have to take your drummel tool with the cutting blade and cut slots in the screws, after you get this done it is important to count the number of rotations in until stops make note how many. because you are going to reset the same way.now remove the screws,put a side when you get ready to put screws in put in all the way than back out as many turns that you noted, now that is factory set there should only be a small adjustment to do. hope this helps,,
Was this helpful?
Yes
No
Popular Solutions for Poulan Wild Thing 2375 18" Gas
Questions and Unsolved Problems for Poulan Wild Thing 2375 18" Gas
Do you recommend Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin?
Answer
Answer
chain brake on challenge extream seems to stiff to turn
Answer
The model is in bits and I need to assemble it and require the procedure. All the parts are with me.... (More)
Answer
Will not start. Has spark, gas,chain oil,on/off switch is on,choke is on or off, will not start. Is... (More)
Answer
14" Homelite chain saw, virtually new. Runs fine for 15 minutes, then quits. Won't start again... (More)
Answer
ut 10045c won't start will i need a new coil
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Poulan Wild Thing 2375 18" Gas...:
Top Chain Saw Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Chain Saw Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
