My LG 37LC55 LCD TV has one half of the screen darker than the other
My new TV has one half darker and with less contrast than the other.This is especially noticeable where a tv show has large areas of whiteor light colours. There is a distinct and clear division down exactlyhalf the display which seperates the dark and light sides.. Any ideas?Thank you.
  • 4 more comments
  • mikeuk Jan 06, 2008
    Example photo of problem..
  • mikeuk Jan 27, 2008
    Thanks, but no, the XD demo was off. Turned out to be a dud board (there's one board for each half of the display on this model) Got a new TV under warranty which works fine. Thanks for your reply, though :o)
  • Eric Hart Dec 20, 2008
    I just started having the same problem on my Mitsubishi WD-62528. I just changed the lamp two weeks ago.
  • Anonymous Mar 28, 2009
    When I turn on my Toshiba LCD TV (37") the right half of the screen is darker than the left half. This goes away after several minutes, is this just a warming up issue?
  • Anonymous Mar 18, 2014
    The screen is getting darker
  • Anonymous Mar 26, 2014
    How can I repair one side being darker than the other?
Is the XD Demo on. This shows half of the screen with the XD picture engine on and the other with it off. Check your picture settings in the menu.
Good Luck
Posted on Jan 27, 2008
Hi i have the lg42lh3000 lcd tv and half the screen is darker than the other
The CCFL (Cold Cathode Fluroscent Lamp) at the darker end is not lit. Either the CCFL is fused or the ballast is needing repairs.
Jun 18, 2011 | LG 42LG30 42 in. LCD HDTV
We recently got a new LG 42" 1080p HDTV and occasionally the screen goes dim/gets slightly darker while we are watching shows. It is not the show as I have tested the same spot the dimness occurs...
It can be the auto-contrast is doing its jobs so LG can claim that the TV has really high contrast ratio, also try turning off auto brightness feature off. It gets real bad when the scene has dark back ground such as the dark sky with stars, the TV will really dim down to give real black sky but at the same time you can barely see the stars on the screen, LG is not the only one with this design problem, VIZIO and other has the same problem as well. If you Google your model and search for review you may see that you are not the only one with this problem.
What is the exact model of this TV.
Please let me know what you find.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Mar 09, 2011 | LG 42 in. Flat Panel LCD HDTV
There is a dark soot-colored shadow shaped somewhat like a long irregular finger or leg that runs down the left third of my screen. This appeared about two months ago and never goes away when the screen...
I have had the same problem for a couple of Months . Bought my lg in March 2009, just had it diagnosed as the Screen . Apparently they are not Lg screens but a version called AUO optrix . my tv is a non economical repair and i am waiting for Currys to get back to me . let me know if i can be of any help. Mike my model number is 42LG5010 ZD
Oct 10, 2010 | LG 42LG50 42 in. LCD HDTV
My tv has one half darker and with less contrast than the other.
This can be fixed easily at a local TV repair shop. I would not recommend trying it yourself as the components that you need to touch carry and electrical charge,
Jan 12, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
LG Flatron w1952TQ screen half darker on right side
Try clicking the auto adjust button on the screen. If this doesn't work it may be in demo mode, so click the fENGINEbutton on the monitor and make sure it is selected on the normal setting.
Aug 04, 2009 | LG Flatron L1919S LCD Monitor
Top half of screen is darker than bottom half
The problem is most likley the TV backlight - it is very unlikley to be the graphics card or video input or any other circuitry within the TV.
Also, the problem can be manifested by flashing or flickering of one or both halves of the screen, and sometimes it is a left/right split rather than a top/bottom split, depending on where the lights are positioned. Before failure, you sometimes hear a very high frequency buzz for a few weeks before it fails - the frequency can't be heard by most adults as it ranges from 15kHz-25kHz, but children\animals can usually hear it.
Generally you will need to replace the backlight tube or the invertor that drives it. Generally you can identify the backlights as thin glass tubes buried deep within the panel itself usually with one wire going to each end of them - they are very fragile. The invertor is connected to the backlight tube and looks like a circuit board, often containing a high voltage warning. Usually there are two or four conductors connecting the invertor to the tubes, which can be identified as thicker individual wires as opposed to the flat ribbon wire used for data for the actual image displayed on the screen.
On some screens you may be able to unplug\swap one or both tubes to identify if it's the tube or inverter.
Oct 05, 2008 | Televison & Video
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Jul 08, 2008 | Televison & Video
One half of screen sees darker than other
Problems described are related to Backlight.It is possible that backlights of affected area have become weak.
You may need to contact the company for repairs and Yes the Repairs may not be cheap.
Nov 01, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
2,662 people viewed this question
Top Televison & Video Experts
