Question about Mitsubishi WS-65807 65" Rear Projection Television
Ws65809 projection tv
My tv does not stay on after powering up and I get a code of 23.
I have already received some suggestions on how to fix from your tech support.
I need to know where to get parts and if it would be better to replace the whole circiut board?
  • Mitsubishi Master
  • 8,617 Answers
You can purchase parts online at these two links
http://electronix.com/ or http://www.matelectronics.com/
Either one should be able to help you out. If they dont stock your part check back with me and let me know exactly what your looking for and i will post a link for you. Hope this helps.
Posted on Jan 05, 2008
Mitsubishi ws65809 error code 23
i would recomend you to send it to some repairman, but still i can tell you it must be a transistor..and its better for him to fix it
Dec 21, 2007 | Mitsubishi WS-65809 65" Rear Projection...
I have a mitsubishi model ws65809 big screen tv. When I turn power on it only stays on for 10 seconds then shuts off. I checked the fuse but fuse was fine.I want to know if I changed the lamp will it fix...
You will need to press the menu button and the input buttons on the TV both in together for five secoinds then count the two digit blink code from the power indicator. the blink sequence will repeat several times. let me know the sequence of the blinks.
May 30, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Tv stays on for awile and then turns itself off
23 is horizontal deflection failure. The problem may be the high voltage power supply or bad connection(s) in the yoke circuit.
May 28, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
What is a code 21 on a WS65809 mean? My red crt is not working.
X-Ray Protect circuit error code 21, make sure your counting it right because code 12 is no error
May 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Ws65809 tv
Good Day, TRAVLINMAN80;
Sorry for the late response but have been dealing with IKE down here in TX. I think the problem your TV is Fluid. Good Luck, big IRISH.
Sep 13, 2008 | Mitsubishi WS-65809 65" Rear Projection...
MITSIBUSHI WS65809 TV
Good Day, GLENN;
I assume that IHVT was arcing from the side, and the audio is from the TV and not stereo? Or was it the high voltage splitter? Was it plug in or soldered IN? It sounds like you may have bridged a solder joint, unplugged something by accident or something else? Double check your work first of all. Do you still get high voltage? You may poor part. Good Luck, big IRISH.
Can't find parts
http://www.mouser.com/index.cfm?handler=home http://www.mcmelectronics.com
http://www.bdent.com
http://www.electronix.com
Jan 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
