Question about Distinct Audio D600 POWER AMPLIFIERS [2-CHANNEL 600W] ( Audio D600) Car Audio Amplifier
How to use Distinct In AlliesName using Query
CgQuery = "select a.StudentName,d.AdmissionNo,b.ClassName,c.CurrentSection from StuAdmission as a,StuMasterClass as b,StuSectionDetails as c,HostelAdmissionDetails as d,StuClassMapping as e where d.AdmissionNo=a.AdmissionNo and d.ClassID=b.ClassID and e.ClassMappingID=c.ClassMappingID and e.ClassID=d.ClassID and a.CompanyID=d.CompanyID and b.CompanyID=c.CompanyID and d.CompanyID=e.CompanyID and StudentPresentStatus<>'L' "
Sir,In this Query I want to take the distinct (StudentName,AdmissionNo,ClassName)
thankyou,
(D.chandramohan)
  • chandra mohan Jan 05, 2008
    Sir,Give me Quick result for this problem
  • 39 Answers
You probably want a GROUP BY query on the three attributes you specified, and select what kind of aggregation you want (first, last, sum, avg...).
Regards -- Joe
Posted on Feb 07, 2009
Sony kv 35s36 won't come on at all. No click, sound, hum, buzz, nothing.
blown power supply.... I have the same tv... but with a fault in the main board leaving me with a flashing image. I have a power supply that's good and you have a main board that's probably good.....??? function SOswitchMenu() {var el = document.getElementById('bodyDiv');if ( el.style.display != "none" ) { el.style.display = 'none';}else { el.style.display = '';}var el2 = document.getElementById('h2');if ( el2.className == "calHeader goog-zippy-expanded normalText" ) { el2.className = "calHeader goog-zippy-collapsed normalText";return;}if ( el2.className == "calHeader goog-zippy-collapsed normalText" ) { el2.className = "calHeader goog-zippy-expanded normalText";return;}} function SOframeReload() {var f = document.getElementById('soFrame');f.src = f.src;}
Sep 11, 2010 | Sony KV-35S36 35" TV
Distinct ring function for fax?
Setting The Receive Mode
  1. Press <FAX>, then press <Menu>.
  2. Press <OK>.
  3. Use [<]or [>] to select the receive mode.
  4. Press <OK>.
Aug 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
How do I set the time on this watch?
Hi, function SOswitchMenu() {var el = document.getElementById('bodyDiv');if ( el.style.display != "none" ) { el.style.display = 'none';}else { el.style.display = '';}var el2 = document.getElementById('h2');if ( el2.className == "calHeader goog-zippy-expanded normalText" ) { el2.className = "calHeader goog-zippy-collapsed normalText";return;}if ( el2.className == "calHeader goog-zippy-collapsed normalText" ) { el2.className = "calHeader goog-zippy-expanded normalText";return;}} function SOframeReload() {var f = document.getElementById('soFrame');f.src = f.src;}
I had a watch similar, and it's actually very easy to adjust as soon as you have the solution, so:
You need a very thin stick (maybe a toothstick or a think pencil). 1) Stick it into the upper pinhole (on the right side on the watch). Then it starts to blink. 2) Adjust by pressing the lowest pinhole 3) Confirm with the upper pinhole 4) Now you'll go through each step (hour, minute, date, 24/12h, etc.) 5) Finally you will se the time on the watch (not blinking), If you press the lowest pinhole you can choose between: - static screen showing time - static screen showing date - shifting screen showing both time and date
Br. M
Dec 14, 2009 | DKNY NY1304 Watch for Men
Using Microsoft Query to bring Access 2007 data into a spreadsheet
Try using Data > From Other Sources and select From Microsoft Query. In the Excel sheet, select the cell that you want the results to start in. Your MS Query would be pulling the data from your Access database.
May 04, 2009 | Microsoft Excel for PC
How can i connect the data base during my project
That seems fine.
I cant assume your level of confidence in programming, however, following are some simple steps you can follow to achieve (for complex implementations, much more time and details will be needed, i can help u with them as well)
1. Create a database in Access ( i assume u r using Access 2003)
2. Create a System DSN (if aren't clear, how to create then goto administrative tools under control panel and you'll find Data Sources (ODBC), here u need to create System level DSN for Access driver (may be Jet 4.0+)
3. In java, you need to import java core libraries for sql (javax.sql package specially)
4. you are almost done, just google for database code in java, simple code will be around 5-10 lines (just for your reference, search with these keywords, ClassName(""), jdbc:odbc:YourDSN)
5. Open a connection using Connection object
6. Fetch the records (select query) using Recordset object
7. You're done.
thanks
Kuldeep
Mar 13, 2009 | HP Computers & Internet
How to create a multiple access query and put altogether into 1 SQL Scrip(.sql file)
Suggest using Union Query. Thus, you can add more queries from many table and the output will be in one (1) query. Bear in mind that all fields must have same Field Name.
For example:
tblOne contains dtDate1 fieldname. Your query will select [tblOne].[dtDate1] As myDate.
tblTwo contains dtDate2 fieldname. Your query will have the following SQL:
Select [tblOne].[dtDate1] As myDate
UNION Select [tblTwo].[dtDate2] as myDate
Thus the output will result dates from tblOne and tblTwo in a column called myDate.
Regards,
Maha
Feb 05, 2009 | Microsoft Computers & Internet
I need to set Distinct ring
Press Function then Data Registration press set use the Down arrow to RX setting press set scroll down to RX mode press set Scroll down to DRPD press set pess set again at Drpd Select fax and Choose your ring type.
Apr 09, 2008 | Canon FAXPHONE L80 Laser
Microsoft Access Query
Your date form is what it wrong. In order to use dates in Access with a BETWEEN function clause the values have to specifically be dates.
You can create dates in literal strings using the # sign to bound them, as in:
Select DISTINCT [ActivityDate] between #1/1/08# and #12/31/08#
#....# tells Access to treat this literal string as a date.
If you are using non-literal values, such as a parameter handed into the query, which would then be a variable, you can't use #some_variable# to cause Access to view it as a Date since #...# is for literal values only. To convert (also called "casting" a variable), use the CDate function. CDate likes to know what format to expect the string to come in though so it helps to pass that along, as in:
Select DISTINCT [ActivityDate] between CDate(begin_dt_string) and CDate(end_dt_string)
Remember the date string you pass into CDate has to be readable as a date by CDate. So make sure you pass in something that it can handle (use the IsDate() function to check to be sure so you can avoid a runtime datatype casting error). If your locale is US, then passing in x/y/z it will take for MM/DD/YYYY. If Europe, it will take it as DD/MM/YYYY. So keep that in mind.
To convert out of a date, use the FORMAT() function. That is how you get a date data type value to become a string value.
More fun reading:
http://www.techonthenet.com/access/functions/datatype/cdate.php
http://www.techonthenet.com/access/functions/advanced/isdate.php
http://www.techonthenet.com/access/functions/date/format.php
Hope this helps!
Feb 11, 2008 | Microsoft Office Access 2003 (077-02871)...
Distinct Audio D600 POWER AMPLIFIERS [2-CHANNEL 600W] ( Audio D600) Car Audio Amplifier Logo
103 people viewed this question
Top Distinct Car Audio & Video Experts
xxxxxx xxx
Are you a Distinct Car Audio and Video Expert? Answer questions, earn points and help others
