Question about Kenmore 74602 Gas Dryer
Kenmore 70 Series
I have a Kenmore 70 series gas dryer that is not heating up. I used it one night and the next day it would not heat. However if I continue to restart the timer the clothes eventually dry but not by heat.
Help!!!!
  • 4 more comments
  • mrfixer48 Feb 27, 2008
    Kenmore 70 series model 11074712200 won't heat. replaced the ignitor but notice the ignitor isn't even clicking. thinking there isn't any signal geting to the ignitor to make it work. anyone have any ideas what i can do?
  • Anonymous May 19, 2008
    70 series dryer doesn't heat consistently
  • Anonymous Jun 06, 2008
    I HAVE THE SAME PROBLEM
    I HAVE THE SAME PROBLEM WITH MY 70 SERIES
  • Anonymous Dec 24, 2008
    I have the same problem, but I also smell gas. Is the thing just not lighting up and the gas is blowing out?
  • DoitToit May 11, 2010
    Is it best to Call the Sear repair man or just call a local repair man? Any benefit either way?
    Thanks for any advice.
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Posted on Oct 06, 2008
I have had this problem twice previously. Both times it was the fuse which is under ten dollars and can be very easily installed from the back of the machine.
Posted on Jan 01, 2009
I am having a problem with kenmore 70 series dryer is gas. Runs for ten minutes warm, then it gets cold. I need help trying to open the panel.
Posted on Mar 29, 2008
  • 90 Answers
Most common problem is the thermal fuse located on gas flame chamber, If thats not it look at ignitor or coils on gas valve
Posted on Jan 05, 2008
4 Suggested Answers
SOURCE: Kenmore 70 Series
Unplug and turn off the gas feed. The fuse is located in the back of the series 70 attached to the lint housing near the bottom. About 1-1/2 inches long. Easy to remove, only two contact wire attachments. Note which wire goes where. Under $10.00 at an appliance parts store. Start with this fix.
If still no heat take out the ignitor assembly, located in the front, lower left. It is attached to the base of the dryer by 3 screws, the gas feed and two electrical wires with removable metal attachments (note which attachment goes where). The entire assembly will come out and the ingitor is attached to the front end. I took mine to the appliance parts store and it tested OK so it was the fuse. The owner helped me locate the fuse and suggested I try this first. The ignitor coil is about $25.00.
Both of these were easy enough for a novice (like me) to do. It saved a lot of money.
While the dryer was open I vacuumed out all the dust and lint and checked the integrity of the belt.
Good luck.
Posted on Oct 07, 2008
  • 177 Answers
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Posted on Jun 07, 2008
  • 105 Answers
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Posted on Apr 07, 2009
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Jan 24, 2010 | Kenmore 63942 Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
My gas dryer stopped heating it is a Kenmore 70 series. I am getting good gas flow but dryer will not heat.
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 07, 2009 | Whirlpool LGR3624JQ Gas Dryer
Kenmore 70 Series
Apr 07, 2009 | Dryers
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
Jun 04, 2008 | Dryers
Kenmore 70 Series
Unless the dryer is extremely old, you do not have a standing pilot. It uses and ignitor or glow coil which could be your problem. It could also be defective gas valve coils or an open thermal fuse. Since it is a gas unit, I recommend you call a technician.
May 09, 2008 | Dryers
Kenmore 74602 Gas Dryer Logo
1,265 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
