Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Was this helpful?
Yes
No
Popular Solutions for HP Officejet 7210 All-In-One
while attempting to fax item a whizzing sound sounds in the scanner area. the message says scanner...
(More)
WHILE ATTEMPTING TO FAX ITEM A WHIZZING SOUND SOUNDS IN THE SCANNER AREA. THE MESSAGE SAYS SCANNER FAILURE TURN POWER OFF THEN ON AGAIN
i have a hp officejet 7210 all in one. it is jamming on the left corner. i opened the back and...
(More)
i have a hp officejet 7210 all in one. it is jamming on the left corner. i opened the back and noticed that one of the 4 rollers does not have the rubber band. is that the problem?
I get the 'remove and check right print cartridge' message on the All in One 7210 window. Can't...
(More)
I get the 'remove and check right print cartridge' message on the All in One 7210 window. Can't solve, won't reset. It was working fine until I changed the color cartridge, then this message appeared and I had never touched the right cartridge.
Hello after about 8-9 reinstalls which will not allow the premium features icons to load on the...
(More)
Hello after about 8-9 reinstalls which will not allow the premium features icons to load on the desktop anylonger my error message has been (the null paramator one that so many have complained about and i still dont see a fix or a work around that just gives no results is it time to buy a different all in one as the games people play cant fix mine so far. concerned in florida this system worked untill i upgrades from a dell 727 to a optiplex gx620 please I want my scanner back
hp 7210 skips part of most characters across a line of print. I replaced the ink cartridge, but that...
(More)
hp 7210 skips part of most characters across a line of print. I replaced the ink cartridge, but that did not help
