Kenmore 22422 Top Load Washer
Problem for Kenmore 22422 Top Load Washer
In spin cycle the basket wont spin causing clothes
By britton_wald on Nov 07, 2009
in spin cycle the basket wont spin causing clothes to stay soaking wet
Best Solution
posted on Nov 07, 2009
Helpful)
justaskjoe
Rank: Guru  Kenmore Expert
Rating: 85%, 2009 votes
hello. thank you for selecting fixya! If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Regards, Joe
Comments:
Nov 07, 2009
- hello. thank you for selecting fixya! If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Regards, Joe
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Kenmore 22422 Top Load Washer
Questions and Unsolved Problems for Kenmore 22422 Top Load Washer
Do you recommend Kenmore 22422 Top Load Washer?
Answer
Answer
The top of the spinning post in the middle of the tub now won't spin when washing (evidently... (More)
Answer
I have a Kenmore Elite top loading washing machine. The machine stops in the middle of a cycle and... (More)
Answer
I have a front loader Kenmore Washer and cannot find the Screen Filter. It looks new in front but it... (More)
Answer
It processes most the load then it reads LD on the display. I just moved in Sat. and this is the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 22422 Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14834
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
