Home | Sony | KP-46WT510 46 in. Rear Projection HDTV Tel... | The Convergence is off...
Sony KP-46WT510 46 in. Rear Projection HDTV Television
Problem for Sony KP-46WT510 46 in. Rear Projection HDTV Television
The Convergence is off and the TV wont allow me to
By michael_krug on Nov 07, 2009
the Convergence is off and the TV wont allow me to fix it, I tried the flash focus and then the manual but the joystick doesnt move the crosses to align with each other
Same Problem
Nov 18, 2009
-   how do i get to manual adjustment for the focus
-   Hoser123
Best Solution
posted on Nov 07, 2009
Very Helpful)
louis66
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 13 votes
If you are fairly handy you can fix it yourself using a kit from www.TvRepairKits.com
Here is more info You can get more info and see some example photos here on Fixya using this link.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Comments:
Nov 07, 2009
- Projection TV sets have several common problems listed below.
Convergence problem.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some pics of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button try pressing the button. If it fails to align the video the convergence circuit has failed. See below for a fix.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
If you are handy you can do it yourself or you can call in a pro.
If you want to do the repair yourself check the site www.TvRepairKits.com. They have kits that include step by step instructions with photo examples, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, and email/phone support.
Problem #2: Lens Fluid needs replacing!!!
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant for the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Here is a pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant,step by step instructions, etc.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
SD Tech
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 97%, 854 votes
This model was first made in 2003 and uses two of the STK-392-560 CONVERGENCE IC CHIPS.
Usually just both chips need to be replaced and the set adjusted with the Sony remote---You can buy a pair of the chips on Ebay for less than 14 dollars plus shipping.
If you can do this repair you can save the set and a lot of money as most shops will charge 300 or more for this kind of repair.
I can give you general instructions if you think you can do it---there are places on the internet that sell
kits for this--usually very pricey and many of the included parts are not usually needed.
IF CONVERGENCE WILL NOT ADJUST: BOTH CHIPS NEED TO BE REPLACED.
IF YOU HAVE QUESTIONS OR NEED HELP, LET ME KNOW, I am here to help people.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Sony KP-46WT510 46 in. Rear
Questions and Unsolved Problems for Sony KP-46WT510 46 in. Rear
Do you recommend Sony KP-46WT510 46 in. Rear Projection HDTV Television?
Answer
Answer
I have a Philips Magnavox Projection TV. I had dish satelight install on my TV. It worked well for... (More)
Answer
the tv picture looks like should be wachting it whith 3d glasse
Answer
replaced convergence clips and blue wave will not line up can move but way off
Answer
How do I get the front panel off my Sony 46in projection tv to adjust the red line conversion.
Answer
Our picture is visible but is in blue tint. How much is that to fix, around? Is there anything... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-46WT510 46 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
