Question about Olympus Stylus 720 SW Digital Camera
Lines through picture
When veiwing pictures i have taken, there are spots or lines through different sections of the picture. Some pictures are also merging with pictures i have previously taken. I have tried numerous memory cards, computers and have formated and reset the cards. Any ideas?
  • 2 more comments
  • makenziele Mar 12, 2008
    the spots on mine are orangey and lines on mine are through the whole picture.
    the picture looks overexpoed and orangey/yellowish in artificial light.
    sorry i didn't mean to post that as an answer and i don't know how to get rid of it
  • Anonymous Mar 15, 2014
    When viewing previously taken pictures, can see only last one taken. Also, there is a bracket win 'IN' on the screen [IN]. I cannot find this in the manual.
  • Anonymous Mar 17, 2014
    Pictures have a shadow/dark spot in the middle. Does not change with new picture card.
The spots on mine are orangey and lines on mine are through the whole picture.
Posted on Mar 12, 2008
Fuji digital camera 350... the pictures have lines in them.. more so when the picture is taken out side
You see the lines at Display camera ? Try download picture to pC and see if show the line.
If the line show in PC and camera display . Replace the lens.
Sep 20, 2011 | Cameras
SAMSUNG S1070 - When I take pictures, white lines appear on them. They don't appear on the screen when I am not taking a picture, and they do appear when I transfer them to my computer. I have tried...
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 29, 2011 | Samsung S1070 Digital Camera
The pictures have horizontal lines through them. The veiw screen is fine. When you review or save them to the computer they show up whiter and with lines. Thanks ahead for any help.
If this doesn't apear on the print pictures taken directly from the SD card. It has something to do with the settings for the picture transferre on your computer.
Try and reset/adjust the settings within the transferre programe. I cannot tell you the eact steps for that since it will depend on the programe you're using. But it can usually be done right before transferring pics to the computer.
If helpful pls. recommend/rate me and or give me a review. TXS
Dec 03, 2009 | Kodak EasyShare Z612 Digital Camera
3-D picture with color lines
Seems TV has dry/ cold solder joints (loos connections) in convergence out section.
Please check cold/ dry solder joints in convergence out section in TV, specially on pins of convergence out ICs. resolder these solder joints and all would be fine.
Sep 28, 2009 | Sony KP-57HW40 57" Rear Projection...
Distorted/damaged pictures
Please check the image size (pixels x pixels) setting or the resolution (MP). Seems like the camera is shooting in low resolution. Have you used this memory card on a mobile phone or another camera? Format the memory card and try again.
Feb 14, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
White lines appearing on display after picture is taken
I have the same problem, and upon looking into my problem, i recall reading that Sony had used crappy glue in which they attached the CCD to the inner guts of the camera, and when that deteriorates, which doesn't take very long, then your pictures will have lines through them.
I think i remember reading that Sony said they will replace all cameras within 2 years of their manufacture. Call Sony's troubleshooting and support and they may replace it for you.
Hope i helped solve your problem.
- Josh
Oct 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Lcd black while in picture taking mode
Your ccd appears to be bad. Canon USA will repair this for free. Go here for details. They will send you 2 emails. One with the UPS label and another with info sheets to be sent with the defective camera
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 28, 2008 | Canon PowerShot A75 Digital Camera
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Lines across picture display.
yes it needs repair. by saying "This doesnt show up before I take a picture" this means their is no problem with the ccd or image taking section. the problem is occouring while saving the photo.you camera needs repair.
Jun 20, 2006 | Konica Minolta DiMAGE G400 Digital Camera
Olympus Stylus 720 SW Digital Camera Logo
432 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
