Question about Kenmore 63942 Dryer
Kenmore 11060052991 No start
Dryer will not run. Repair company states control board is bad. $ 290 to replace. Note I ran the Console diagnostic test and all the touch pad buttons are normal.
One thing does seem odd, though the dryer will not run. When I attemt to start, the check lint led flashes each start attempt. Led turns off when the dryer door is opened. Lint screen is clean, inspected the vent exhaust plenum and the duct for blockage.
If board need to be replaced. Does not seem complicated. Any issues if it is replaced with out othe testing or meters to check.
Priced the board online, seems that pn 3978696 it has been replaced. Price about $ 170.
  • 90 Answers
Have you checked the thermal fuse, if bad replace and clean vent.
Posted on Jan 05, 2008
6ya staff
SOURCE:
Kenmore elite electric stove. model 79099013102. Intermittent starts beeping then flashing "F7".
The "F7" fault code could mean a stuck or shorted key pad/console or it could mean a failed oven control board. There is no way to reset the control.
A service technician would determine if the problem is with Key Panel/Console or the Oven Control by: See image below.
NOTE
: This is intended for the service technician. I do not recommend attempting to diagnose which one has failed. This test must be performed while connected to the power supply.
I recommend calling a service technician to diagnose and repair your range
May 23, 2018 | Kenmore Kitchen Ranges
How do you start diagnostic on kenmore elite smartheat quiet pak 9 HE4 dryer?
Hope this helps
By Manage My LifeDecember 30th, 2011
Kenmore Elite Dryer HE4 Quietpak 9 Model 110.85091400 has 4 dim lights showing on the console display but won't start or respond
Our dryer just quit working yesterday and I am puzzled. There are four lights very dimly lit on the display. They are the Casual button, the Timed Dry button and two of the segments in the oval time window. I have found the information online about how to test with a multimeter to try and figure out which board is bad. Unfortunately all these instructions require you to have the dryer in the diagnostic mode by pressing the More Time/Less Time/More Time/Less Time in less than 5 seconds. When we do this it does nothing and will not enter the diagnostic mode. When I am testing with the multimeter on the P3/P4 connections I am not getting any readings of voltage at all. Is this because of not being able to get into the diagnostic mode? Should I still be getting readings? I know we have power to the dryer because the light still turns on when you open the door. The cost of buying both the main control board and the front console are prohibitive for us and I would like to only buy the one that is bad. I have also tried the testing with the multimeter on the front console buttons and also get no readings of ohms at all. We have a very busy household with lots of kids and this dryer is very essential to us so the quicker we can get this fixed the better. Thank you in advance for your help.
Jul 03, 2015 | Kenmore Dryers
When pts switch is pushed dryer comes momentarily and then shuts off. I've already replaced electronic control assembly and ran diagnostic test, everything seems OK, If I hold pts in dryer runs fine
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 05, 2011 | Kenmore 73952 Gas Dryer
I have a kenmore Oasis that powers up but wont start
Activate the Console and Indicators Diagnostic Test Mode to check the functionality of the .
Console and Indicators Diagnostic Test Mode Activation
  1. While in standby mode, press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press the START button within five seconds of "dt" showing on the display. All indicators should turn on and "88" is displayed.
  3. Press START again. The two-digit display and the status indicators turn off while all other indicators remain lit.
  4. Press START again. The two-digit display and the status indicators turn on while all other indicators remain lit.
  5. Rotate the WASH CYCLE selector back and forth. The indicators will switch on an off.
  6. Press the buttons to check the function. The indicators will switch on or off and a beeping sound will be heard when a button is pressed.
  7. Press STOP or POWER button to exit diagnostic test mode.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the user interface board and its connection to the main/control board.
  • Unplug the machine.
  • Remove the three screws on the back of the console.
  • Lift the console off the cabinet.
  • The control board is located on the right side of the console viewed from the front of the machine. Disconnect the middle wiring harness connector on the right side of the control board near the pressure transducer hose.
  • Clean the connector thoroughly to ensure a good connection.
  • Reinstall the console and reconnect power.
  • Run the diagnostic test once again.
  • Replace the user interface board if it fails the test once more.
Refer to the next post if no problem is found on the user interface.
Jan 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore HE4 Dryer leaves clothes wet
From the techincal document found in the dryer bottom panel
TEST #4a Dryness Level Adjust
NOTE: If the customer is complaining about the clothes being damp and the moisture sensor passes TEST #4 "Moisture Sensor Test- step 3, then the total dry time can be lengthened by changing from a "Lo" for short auto cycle to "Hi" for longer auto cycle.
1. Activate the Diagnostic Test Mode. Press the following button sequence: MORE TIME ~ LESS TIME -+ MORE TIME --+ LESS TIME - all within 5 seconds
1. In diagnostic test mode, press and hold the Auto Dry Level key for 5 seconds. The dryer will beep and the current auto cycle mode will be seen on the display. The factory default setting is "Lo".
1. To select a different auto cycle mode, press the Auto Dry Level key again. The dryer display will flash and show either "Hi" or "Lo"
1. With the display flashing the selected auto cycle mode press the Start key to save the setting and exit diagnostics (the Start key in this mode does not start a drying cycle). The result will be stored in EEPROM of the control board.
SO EASY JUST TOOK ME 3 YEARS TO FIND IT
Ross
Feb 28, 2009 | Kenmore Elite HE4 Electric Dryer
Sears elite he dryer stopped working
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Feb 19, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore front load washer wont spin...
check the motor control board ,,, sound like thats what your looking at
Dec 08, 2008 | Washing Machines
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
156 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
