2002 Ford SVT Focus Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT SIZE NUT IS ON THE REAR DRUMS OF A 2002 FORD FOCUS
  • Marvin
    Marvin May 11, 2010
    DO MEAN THE LUG NUTS?
mike hayward
Level 2:
  • Ford Expert 279 Answers
  • Posted on Jan 05, 2010
mike hayward
Ford Expert
Level 2:
Answers
279
Questions
Helped
159218
Points
642
30mm i think mate
please let me know if this helps
cheers
big mike :)
Tensioner won't move on focus 2002
Yes i would replace it if it does not work or act as it should. this is not uncommon. The whole unit is under $50
How do I get the rear drums off a 2000 Ford focus. I removed the spindle nut,
2000 Ford Focus Drum Removal ProcedureIf removing the drum to service the rear brakes: (note, do not remove hub retaining nut for this procedure)
1. Raise and support vehicle
2. Release the parking brake
3. Remove wheel and tire
4. Disconnect wheel speed sensor wiring harness from wheel knuckle and floor panel.
5. Remove 4 wheel spindle attaching bolts, then the wheel hub and drum assembly from vehicle.
6. Reverse procedure to install noting the following:
a. Torque wheel spindle retaining nut to 49 ft. lbs.
b. Torque wheel/tire assembly to 94 ft. lbs.
2000 Ford Focus Drum Replacement ProcedureIf replacing the drum and wheel bearing assembly:
4. Remove center dust cap.
5. Remove hub retaining nut.
6. Remove drum and hub assembly. Ensure wheel speed sensor ring is not damaged when removing drum/hub (if equipped).
7. Reverse procedure to install noting the following:
a. Inspect and clean wheel speed sensor ring if equipped.
b. When tightening hub retaining nut, rotate the hub assembly in counterclockwise direction.
c. Torque hub retaining nut to 173 ft. lbs.
d. Torque wheel/tire assembly to 94 ft. lbs.
e. Adjust parking brakes as necessary.
2answers
How do you take out the rear drums out of a 2002 ford focus zx3 i took out the four nuts in the middle of drum and still didnt come out
You may have to loosen the brake shoes. And also "bang" on the drum with a small sledge hammer. Generally the will be rusted on and may require a good amount of force.
1helpful
How to remove the rear brake drum on a 2002 ford focus xtw
Ford Focus rear drums are held on by a nut in the middle remove the cap in the center and then remove the nut, new drums come with the bearing as well. IMPORTANT NOTE! ABS PICKUP NOT INCLUDED ON NEW DRUMS MUST BE REUSED FROM OLD DRUM.
I need to remove the rear hub on my focus tdci 2002
Use the drum puller and tap the back side of the drum from with a hammer, and keep tightening the puller. It will come off if you have the security screw's out. The reason it's hard to pull off is BC the brakes are grabbing the drum
I'm dont able to remove rear drum on ford focus 2005
the bearing needs to come apart remove the silver cap you should see a cotter pin holding the spindle nut remove the pin then the lock shield for jam nut then remove jam nut be careful as bearing may fall out there is a washer between jam nut and bearing then you should be able to remove drum
Changing the rear brakes on a 2003 Ford Focus.
I'am not sure what you are calling jam nuts but if you are talking about the spring loaded washers on the lug studs that are pressed against the drum, they are not needed.
2002 ford focus
you need to take off tires at hte back,you gonna see a big metal dust cover,take it off,then you gonnasee a big nut inside on it,that the one holding your drum,good luck and have fun
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
