standing pilot, burners come on and then the pilot gets blown out. When the burners are on I can reach down and re-light the pilot. but after the burners shut off, and the water cools and the burners kick on again it blows out the pilot.
Get a toothbrush and clean the **** off the pilot, could be partially blocked. Change the safety thermocouple. Check the plenum for cracks. A cracked heat exchanger can cause this.
hi i have a 38,000 btu ultra portable heater and when i turn it on it sounds like its starting but...
(More)
hi i have a 38,000 btu ultra portable heater and when i turn it on it sounds like its starting but then it cuts off and theres a red light blinking on the side with no lable by it
I have the blower assembly apart. I have a liquid teflon sealer with a maximum temperature of 550...
(More)
I have the blower assembly apart. I have a liquid teflon sealer with a maximum temperature of 550 degrees fahrenheit. Will this be enough for the hot air from the combustion burn chamber air temperature, when it circulates through the blower assembly? The ribbon gaskets show leakage , and my best guess is, a suitable temperature sealant in addition to the ribbon gaskets would be fine. Also,I found a bearing without a wavy spring washer. What is the correct description of this part? I will need advice on testing the solenoid ,and, when reassemblying the combustion blower assembly,how to syncronize this. I read that this needed a device to accomplish this. What is the name of the suitable device to syncronize the ignition event in the burn chamber ,if I am understanding this correctly?
