Question about Epson Stylus Photo® RX620 InkJet Printer
Card reader on printer will not recognize my micro sd card
The error message says " memory card or disk was not inserted or cannot be recognized". It's wierd because while the card is installed in my phone I can save pics and stuff to it so I know the card works. And another thing using the 1gb card out of my digital camera I can save music files to it using the same card reader slot on the printer..???? I can't figure it out. I really appreciate all and any help you can give and thanks so much for your time.
4 Suggested Answers
6ya staff
SOURCE:
Basti
Edgar Allan Pagayona
  • 1447 Answers
SOURCE: Incompatiblity of R300 & Toshiba 2 GB SD Memory Card
Epson Printers & All-In-Ones:
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED Compact Flash 4 GB Secure Digital 1 GB Sony Memory Stick 1 GB MagicGate Memory Stick 128 MB xD Picture Card 512 MB Smart Media 128 MB
These are the Epson tested memory cards that will work, also includes the suported memo capacity..
Hope this is helpful, pls dont forget to rate solution.
Posted on Apr 20, 2008
Anonymous
SOURCE: card reader not working
I think 1 MB is the limit. Get a cheapy multi USB card reader.
Posted on Oct 30, 2008
Anonymous
SOURCE: Micro SD card
had same problem with my epson rx620 it would not read my 2gb sd card so i tried a 1gb and a 512gb and it works fine so it must be the size of the card
Posted on Mar 19, 2009
How to save videos to sd card to computer
Have a nice day. My name is adieh.
Using your Samsung galaxy phone you can follow these simple instructions:
1. Attach your digital phone to your PC using a USB cable.
2.Check if your computer recognizes the phone as a memory device by clicking on "My Computer" on you PC. See if it has been assigned a drive letter. This will give you access to the memory on your micro SD card.
3.Drag and drop data to the memory card by clicking on the data and moving it to the drive letter assigned to your phone. You can also right-click on anything you want to save. Click on "Save As" and save the file to the drive.
4.Access the data on your memory card using the "Tools" menu on the phone.
Another option is that if you are using a microd sd card reader. You can follow these steps:
1.Purchase a micro SD card adapter, which will allow you to insert the smaller card into SD card readers and computers. Many of the newer phones come with the adapter.
2. Insert the micro SD card and adapter into the card reader. Make sure your computer recognizes by accessing "My Computer" on your PC and clicking on the drive letter associated with your card reader.
3.Drag and drop videos or other data to the drive containing the micro SD card. Or right-click on anything you want to save, and then click on "Save As." Save the file to the correct drive.
4.Pop the memory card into your digital phone. Access it using the "Tools" menu on the phone.
Hope it helps.
Thank you for using fixya.
Oct 11, 2011 | Samsung Galaxy S GTI9000 Smartphone
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
Micro sd
Please try to insert it into another computer if the same error prevails uou have to replace your micro sd its bad.
Apr 30, 2010 | SanDisk 1GB microSD Memory Card
I get a card reader error on my printer when i insert my PNY Micro SD card
Has the card worked before.If it is the first time you have tried,is the SD card an SDHC,as some printers will not read these.Try a standard SD card and see if your printer reads that.Hope this helps.
Apr 12, 2010 | PNY 2GB microSD Memory Card
Computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
Jun 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Micro sdhc card reader will not recognize 8gig card
You problem is most likely to be the fact that your micro chip is a HC chip. HC chips have a new program that is not backwards compatible to regular sd host ports. This is a simple fix, however. If you don't trust downloading programs for it on the internet, just go to target or walmart and get a USB SD card reader, and a SD adapter if you don't already have one. The usb adapter should only be like $10 at most.
Jun 07, 2009 | SanDisk 4GB microSD High Capacity Memory...
Micro SD memory card not recognized by computer
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
May 31, 2009 | Samsung YP-T8 Digital Media Player
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
Micro sd card
Does your computer has an internal card reader?
Aug 14, 2008 | SanDisk Sansa E280 MP3 Player
Open Questions:
Epson Stylus Photo® RX620 InkJet Printer Logo
271 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
