Question about Panasonic CT-32G11 32" TV
CT32SX12F 32" Won't power on
I have a Tau CT32SX12F. Went to turn on one day and just won't power on. Tried a different outlet with same result. The TV is only 5 years old and the extended warranty just ran out in November. Any ideas?
  • 2 more comments
  • slymer Jan 13, 2008
    One day tv wouldn't power up.
  • bfdgc Feb 20, 2008
    same problem here
  • RedRider1000 Jun 24, 2008
    I have CT-32HL44. One morning, dead. How do you get the back panel off to replace fuse? I read it's a Radio Shack 6.3 amp item, four for $2.99, but don't know how to access fuse...
  • Justagurl Jun 26, 2008
    I had the same problem, it just wouldn't turn on. Tt had to be fixed, and they said it was a shorted regulator and the horizontal output had to be replaced. That only lasted about 8 months and it happened again! It's a joke!
When mine it, i had to replace a fuse
Posted on Aug 15, 2008
6ya staff
SOURCE:
Emerson 32 inch won't come out of standby mode
It clearly has a problem not allowing it to come on---the set has a warranty---take it back and either get an exchange---Most major stores will exchange in first 30 days for any reason---if they give you the "it has to go for repair," demand a refund on the spot.
Frankly Emerson is not a very good quality brand and parts and support are nearly zero.
Dec 04, 2012 | Televison & Video
My TV won't come on
Hello Linda,
The set will need to be diagnosed to find the problem. There could be an issue with the power supply or main board but get it checked out.
Sep 23, 2012 | Vizio L32 32 in. LCD HDTV
Tv won't turn on
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Coby TFTV3225 32 in. LCD TV
Have a Sylvania 6727DF TV and it won't turn on tried different outlet different remote checked the transistors I can't find what's wrong even the ohm's r weak on the cord
Contact any experienced service technician. Its main power regulator section has the fault. The work is a skilled one, and not a user repairable fault.
Aug 26, 2012 | Sylvania 6727DF TV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
My 32LV67U 32 in. HDTV LCD TV/DVD will not come on, no electrical surge, been mounted on wall since 2007 never been down just went out one day for no reason, now won't come back on
Might be the power supply, try out a company named ShopJimmy.com. They have been great to me in the past and are always helpful. I included a link from your model page on their site. Hope that helps!
[email protected]
http://www.shopjimmy.com/catalogsearch/result/?q=32LV67U
Aug 30, 2011 | Toshiba 32LV67U 32 in. HDTV LCD TV/DVD...
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Televison & Video Logo
180 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
