I donwloaded new driver from the Acer web site for ATI Radeon Xpress 1100, when I try o install them I get a message that says,
SETUP CAN NOT PROCEEDS THE LENGHT OF THE SPECIFIED DIRECTORY PATH PLUS THE INSTALLATION FOLDER NAME EXCEEDS 88 CHARACTERS.
My second issue is when I move the laptop around and turn it on it won't find the hard drive, I have to turn it on and off at least 3 times for it to boot up. Sometimes I get a blue screen that has a message that is dumping memore and a code 0x00000007???
I appreciate any help you guys can provide, Thank you
Make a folder on the c drive in the root directory called "driver". Move the files you downloaded into that directory. You can install now because the directory path will only be C:\driver\installXXX
Your other problem is a loose or defective hd. If loose try the screws, if defective replace.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5100 PC Notebook
I just recently got an acer aspire 5100. the orbi cam at first it did not work. i had to downloaded...
(More)
I just recently got an acer aspire 5100. the orbi cam at first it did not work. i had to downloaded and remove the bison program 3 times and it finally worked. but i can't take pictures with it. not only that but it does not work with windows live messenger. can someone help me pleasee!
i have acer 5100 running UBUNTO 9.4.The system is not detecting any usb external media, (flash...
(More)
i have acer 5100 running UBUNTO 9.4.The system is not detecting any usb external media, (flash drive). PLease help
