hi i have just fitted a new mixer tap when i turn either hot or cold levers off it takes about thirty seconds befores water stops any ideas to put this right thanks.
After installing a new disposal in an LG Highmax composite kitchen sink, a 120 degree crack appeared...
(More)
After installing a new disposal in an LG Highmax composite kitchen sink, a 120 degree crack appeared approximately one inch outside the drain radius. This sink is glued to the composite counter top. Is there a way to repair this sink?
i would like to know the trunk line please help me......because i want to talk to my father....his...
(More)
i would like to know the trunk line please help me......because i want to talk to my father....his name Neson David...thank you...
Hot water Tap would not close off - had to run Hot water system down to unscrew hot water tap...
(More)
Hot water Tap would not close off - had to run Hot water system down to unscrew hot water tap fitting - seems the plastic grummet Lock has worn away
