Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
Press action button to enter MENU.
Navigate to SETUP.
Scroll down to CONVERGE.
Press VOL > to select.
Press CH buttons to navigate up or down.
Choose CONVERGENCE ADJ or RESET TO DEFAULT.
If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left center of cabinet.
Press ACTION button to display red center correction screen.
Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION Remote Control must be in TV mode.
Press ACTION button to display red correction screen.
Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
Use the navigation buttons to align the RED cross with the white cross pattern.
Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
To exit press ACTION button repeatedly, then press CH up.
Comments:
Nov 07, 2009
- If you cannot align the convergence on the menu due o skewed lines, one or both of the two convergence chips that your set uses is bad. They need to be replaced. You may need the service of a qualified technician to do it. Just post it here if you cannot adjust the convergence on the menu to give you further instructions in replacing the chips.
our Panasonic PT-47wx53g TV turns on for just a second and then clicks off ... do you have any...
(More)
our Panasonic PT-47wx53g TV turns on for just a second and then clicks off ... do you have any suggestions on how to fix?
Panasonic PT-47WX53 53" projection TV TV shut down with 3 blinks.I replaced one resistor and...
(More)
Panasonic PT-47WX53 53" projection TV TV shut down with 3 blinks.I replaced one resistor and both I/C chips and TV turned on and stayed on for about 5 minutes and at convergence set up on TV, screen started bouncing and TV again shut down. I then replaced all the back resistors and TV turned on and again shut down with 1 blink. I replaced remaining resistors on front I/C with no luck. SD Tech had me to unsoder I/C and TV turns on and stays on. He had me to install two more new I/C. Still no luck. I have replaced all resistors and convergence chips two times. with chips sodered TV can be turned on with light box on table with remote but shuts down in a few seconds. When I unsoder the I/C chips TV will turn on and stay on until I turn it off with remote. This is the same thing that happened with first set of I/C chips. SD Tech has been very helpful.Can He or anyone else help solve this problem.
I need an upgrade for my Matsushita Wireless Manger. It will only run on XP computers and I need a...
(More)
I need an upgrade for my Matsushita Wireless Manger. It will only run on XP computers and I need a newer version to run on both XP and Vista, and probably Windows 7.
