I have vertical lines in the center of the T.V. It started with one red line and now it has moved on to several diffrent color lines. Also, if the volume is up the T.V. turns off; this started when the lines appeared. I searched the previus problems but only found horizontal lines situations or situations that just talk about one problem. I don't know what to buy to fix the problem (long term)? please help!
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image tv turns on and shots down in 2sec flashing pixels on screen dark image has sound but no video screen goes black and then return to normal picture vertical color lines on screen no video vertical color lines with video vertical bars on screen horizontal lines on the image picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working just right part of the screen is working vertical and horizontal lines on screen part of screen not working some functions not working no video but has sound functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Vertical lines or streaks
Check for a leak where light might be entering the printer.
Check for circumferential scars on the photosensitive drum. If scars are present, replace the
drum cartridge if the line goes through all colors.
Check for circumferential scars on the upper fusing roller. If scars are present, replace the upper
fusing roller if the line goes through all colors.
Remove the imaging drum and inspect main charger or imaging drum for a contaminant, such as
a fiber, if the line goes through all colors.
CAUTION Do not expose the imaging drum to light for more than 15 seconds. The drum is light sensitive, and
exposure to light can cause permanent damage.
Vertical black lines
The toner cartridge is defective.
The toner cartridge is not seated properly.
The fuser entrance is dirty.
The fuser has scratches on it.
This might be a repetitive defect. If so, the lines will repeat at a consistent interval down the page.
The printer needs to be cleaned.
There is a problem in the heating element.
Vertical white lines
If white lines or streaks appear only in the black areas of the printed media, print several
configuration pages to clear the anomaly. If this does not clear the problem, check the sleeve
surface to confirm the defect, then replace the black toner cartridge.
If white lines appear only in a particular color, try printing several configuration pages to clear the
error. If the error does not clear, check the sleeve surface to confirm the defect, then replace the
defective toner cartridge.
There is a lack of toner or the toner cartridge is faulty.
There is dirt in the laser path.
The fuser is defective.
A mirror in the laser scanner is dirty.
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
