Changing Bush LCD TV to PC Monitor mode
The instruction manual tells me to press a certain button on my remote, there dosen't seem to be the correct button
    President:
  • 2,976 Answers
The site won't let me back on your other question about the audio book player. They aren't mp3's, they have their own setup. If you look at one with Windows Explorer, you will see that they don't seem to have any reasoning in their file system. The only way to play them on a regular player, is to get an audio CD, rather than an MP3 audio book.
Posted on Oct 15, 2009
I have a bush dled32165hd tv and ny remote has broken a reminder popped up and i am unable yo change back to my sky box from the built in freeview is there anyway to manually press select
There should be a button on the left hand side of the tv.
I can't attach a link properly but the one below takes you to the correct page in the manual. If it doesn't, you need chapter 8.
http://www.manualslib.com/manual/982577/Bush-Led22134fhd.html?page=8#manual
Aug 17, 2016 | Bush Televison & Video
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
Mar 16, 2016 | LG Televison & Video
The control of My dishnetwork sat remote control does not work with my Viore LCD TV Model EL 404.The current list supply with the remote control of dish network show some numbers but any work with my TV....
Hello, my name is Cheri Torres and I am with DISH Networkcustomer service. I came across your post and wanted to see if I could helpwith a solution. Sometimes some of the codes we have available for certainbrands of televisions are not compatible with certain models of that brand. Ifnone of the codes are working when trying to address your DISH remote to yourTV, we do have an option to run what we call a channel scan. A channel scanwill basically scan through all possible remote codes, until if finds thecorrect one for your specific TV. I hope you find these instructions for achannel scan useful and please feel free to post back here with any furtherquestions or concerns. You can also email me at Cheri.Torres@Dishnetwork.com.
Instructions for running a channel scan
  1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.(For your case press and hold down the TV mode button), then press (500) in the number keypad, then the pound(#) button once and release. You should see the TV button flash three times.
  2. Once you have completed the first step you will again press and hold the TV mode button until all the mode button light up at the top of the remote.
  3. Press the big red power button on the remote once and release.
  4. Press the Up button once every second while pointing the remote at the desired equipment.(press the up arrow as if you were changing the channels up). Keep doing this until your TV powers off.
    Note: If the code for the equipment comes up, the equipment will power off.
  5. As soon as your TV powers off, Press the POUND (#) button right away. If the code entered is valid for the remote, the mode light flashes three times.
Nov 24, 2010 | DISH Network IR Remote Control
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Oct 10, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Bush LCD
Hi Trev.
Do you only get the sound when using the tv tuner eg chans 1 to 5 ?
Or is it only when you try to play dvd,
http://dysonmanuals.inc.io/
Chris..
Nov 28, 2007 | Bush 5693D 24" TV
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
