If it is not installed anymore then it probably broke on one of the ends. Check to see if you have a little square hole on each end. If you do then you will have to remove the cover to reattach. There is a hook on each end of the printer that the square hole attaches to. There is also a slot on the back of the carriage assembly (where the ink cartridges go into) and the encoder goes thru that slot and then attaches to the ends.
Testimonial: "i do still have both holes attached on each side. this is good news that i am able to repair it! thanks so much! "
you answered a question for me about my encoder strip on my dell v305, i did take the top off the printer so i can see, and have better access now, but now im still not sure what to do. i have a few questions
#1 the arrow on the one end of the strip, should be that be on the left or the right of the strip and should it face up or down?
#2 where should i be attaching the ends of the strip? i see a metal prong on the left side and a spring hook thing on the right side, but im not sure if this is where it should go?
#3 where does it slide throught the back of the carriage assembly?
im confused =( thanks in advance
